Replacement AC Manifold Hoses for '75 98 Regency?
Does anyone know where I can find replacement AC hoses for a '74-'76 full-size Olds with a VIR system?
Going to be recovering the R12 from my system and replacing the failing A6 with a new Alma A6 and would ideally like to replace the hose set as well, as that's the only part I didn't replace or rebuild.
The AC hoses have seals in each fitting connection . So i wonder if you can get the right fitting on a new hose to match what is needed to connect to original fittings . i may be into the same thing very soon .
