Replacement AC Manifold Hoses for '75 98 Regency?
Old May 12, 2025 | 11:15 AM
SirVelociraptor's Avatar
Does anyone know where I can find replacement AC hoses for a '74-'76 full-size Olds with a VIR system?
Going to be recovering the R12 from my system and replacing the failing A6 with a new Alma A6 and would ideally like to replace the hose set as well, as that's the only part I didn't replace or rebuild.
Old May 12, 2025 | 11:52 AM
Did you check Kanter and Fusick ?
If they don't have the AC hoses you'll probably have to get them fabricated at a hydraulic supply shop.
Old May 12, 2025 | 06:09 PM
307-5a's Avatar
Roy Ale
The AC hoses have seals in each fitting connection . So i wonder if you can get the right fitting on a new hose to match what is needed to connect to original fittings . i may be into the same thing very soon .
carpenternotmechanic
Aug 12, 2024 02:49 PM
cublex
Jul 15, 2022 02:04 PM
cdrod
May 15, 2020 08:45 AM
Zachary Singleton
Oct 21, 2016 05:47 AM
1FSTLS1
Mar 4, 2008 06:45 AM
