1966 Cutlass Cutlass AC compressor
Old Aug 25, 2025 | 08:38 PM
Mr. Machine's Avatar
So I had 2 AC compressors. My original and one someone gave me a long time ago. My car has been totally apart for a very long time. It’s a frame off and now things are really coming together. I rebuilt the wrong compressor by mistake. The original AC compressor was a model: 5910738. The compressor that we installed the new seals and o-rings on was a model 1131443. The 443 was used from 77 to 80 in Buicks. When the rebuilt 443 unit didn’t fit, I seen why. The front mounting bracket had an offset to it. The 443 unit also had a pressure switch on the back, which my original did not. The 738 was used in the 60s to the early 80s on a whole lot of GM cars. The a6 compressors look so similar. Also the pulley seems different. Am I screwed and I have to do the same rebuild to my 738? I know that I could swap the mounting plates. The extra pressure switch won’t be hooked up and it seems like the pulley position for proper belt alignment might be off. Should I try to switch pulleys and mounting plates?
Old Aug 26, 2025 | 05:48 AM
Here are the two compressors.
File Type: jpeg
KVP
Aug 6, 2024 07:23 AM
FStanley
Sep 7, 2023 10:09 AM
goatwgn
Jul 7, 2022 06:08 AM
goatwgn
Aug 19, 2015 01:57 PM
TheBirds
May 27, 2012 06:30 AM
