1983 Delta 88 heater box water leak
When I turn on the heater after a heavy rain or a car wash, water sometimes pours out of a seam on the bottom of the heater box under the dash (above passenger footwell, close to the firewall). It is definitely fresh water (not coolant), and the only way I can imagine it getting into the ventilation system is through the cabin air intake in the cowl. My questions are: should there be some kind of drain that allows water that made its way into the intake escape? Should water be getting in there in the first place? Is there another common way exterior water can get into the ventilation system? And finally, Why does the water only pour out when I turn the blower on?
The rubber drain elbow comes off of the barb on the heater box. Most times you can loosen up the debris with a wire stuck in the hole. Obviously success with that method depends on how much crap is inside the heater box.
I never managed to find that hose, but after poking around for a while, I found two holes, one under the evaporator box, and a smaller one under the heater core. I poked a wire in each, and water began pouring out the heater core hole. I didn't see any crap get released, but hopefully that fixed the problem.
Thanks for your help.
