Few questions about my car
Old Apr 9, 2023 | 01:34 PM
philv1983's Avatar
So first, the coil has a capacitor on top of it that's not hooked up. Is it needed and if so what does it hook to?
2nd I'm trying to figure out the right pieces for the breather to air cleaner.
3rd what goes here in the ac box? Pics below.
Old Apr 9, 2023 | 01:41 PM
Falkon's Avatar
The last one would be an ambient temp. switch, which keeps the A/C compressor from engaging below 30 degrees. The green wire to the A/C compressor coil runs through it. Assumes the compressor isn't directly connected & this was bypassed. You're better off safety wise, running a steel line from the fuel pump to the carburetor. I definitely don't recommend plastic fuel filters in the engine compartment.
Old Apr 9, 2023 | 01:47 PM
The capacitor on the coil is for radio noise suppression and is connected to the positive side of the coil. If you aren't running points and/or don't listen to AM radio, it's not required. They are still available for replacement the rating is 3mf.
Old Apr 9, 2023 | 01:49 PM
philv1983's Avatar
ok thank you. Not really a problem here in Phoenix. Lol
Old Apr 9, 2023 | 01:50 PM
philv1983's Avatar
radio doesn't work so I guess I could delete it then.lol thank you
Old Apr 9, 2023 | 01:58 PM
rocketraider's Avatar
Oldsdruid
The round hole visible in side of your aircleaner pan is where the breather's fresh air tube connects. Needs a rubber grommet which is available thru the repro parts suppliers or sometimes you can find them at your parts store.
Try rotating the pan so the snout points to the driver side and see if that round hole lines up better with the breather air tube.
*edit* Looks like the breather is in passenger side valve cover. Is the PCV valve in the driver side? You may need to reverse those to get everything to line up correctly.
Old Apr 9, 2023 | 02:10 PM
philv1983's Avatar
yes pcv is driver side. I may leave it alone as long as it won't hurt the engine.
Old Apr 9, 2023 | 03:01 PM
66SportCoupe's Avatar
You might want to consider getting rid of the plastic fuel filter and rubber fuel line on top of the engine.
Old Apr 9, 2023 | 04:52 PM
Sugar Bear's Avatar
X3 on getting rid of the plastic fuel and the rubber hose, it is a fire hazard that I've seen go bad. Put steel tubing with flared tubing nuts on the pressure side of the fuel pump just like the factory. Rubber hose and an inline filter are fine on the suction side of the pump.
Good luck!!!
pettrix
Jan 10, 2022 08:22 AM
spgosselin
Feb 8, 2021 09:23 AM
spgosselin
May 26, 2020 10:09 AM
oldaman
Jan 6, 2020 10:36 AM
scrappie
Apr 10, 2019 05:47 PM
