door window down stop bumpers?
Old Feb 28, 2026 | 06:40 PM
72OldsCut<'s Avatar
Barry
For 72 Cutlass S 2 door hardtop.
I was working inside the doors. I removed the 2 lower window down stops. I dropped one of them and the 'rubber' part broke off (it's 55 years old and very hard/brittle). I have looked extensively and cannot find a replacement rubber bumper. The 31 May 1980 Parts Catalog shows it as a single assy consisting of the steel bracket and the rubber bumper. I only need the rubber bumper, but I cannot find either the bumper or the entire assy. Anybody knowing a source would be appreciated. I can modify the broken one and make it work but would rather have a new not-so-brittle part.
Dimensions of the rubber: 1 11/16" (43 mm) diameter, 1/2" (13mm) thick, mounting hole in bracket is 3/8" diameter.
See attached photo
72 Olds Cutlass S door window down stop bracket and rubber bumper (broken)
Old Mar 1, 2026 | 10:31 AM
70Post's Avatar
They are repro'd I think.....will look around
Found some...Ames Performance Engineering has them....$6 each PN F153
Worth ordering to get one of their paper catalogs (specify GTO).
Of course there are probably plenty of good used originals out there as well....most likely hard as a hockey puck as well so get the bracket w/the puck still attached if going used original.
Old Mar 1, 2026 | 07:16 PM
72OldsCut<'s Avatar
Barry
Thanks much, Patton.
I also found some possible alternatives on Auveco, their #4265, 4265B, or #4236. I can't find any dimensions on their website, so I'm planning to call them Monday 2 march.
I will also check the ones you found at Ames.
Thanks again.
W-Oldzfan
Nov 2, 2023 03:20 PM
Phoenix8990
May 10, 2021 06:30 PM
Tiger69
Body work
Jan 10, 2018 11:48 AM
JCMC64
Jul 31, 2014 05:59 AM
Chumley
Jul 26, 2013 09:53 AM
