PDA
View Full Version : Cutlass
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16
  1. How many 68 ramrod & 69 w-31 are out there?
  2. Throttle Cable Installation
  3. Gas Gauge Dilemma-Part Deux
  4. Rear window..
  5. Cutlass T-tops
  6. 1984 Cutlass Calais (NEED HELP)
  7. Hi!! from GINA1
  8. turn signal housing.
  9. 1972 Cutlass S Shocks
  10. differences between 70 and 71 doors??
  11. 72 Conversion to manual
  12. What's wrong with this picture ?
  13. New Bumper
  14. 1971 To 1972 Olds A body Differences - Spotter's Guide?
  15. 1970 cutlass s vs 1972 cutlass supreme headliner
  16. What AC components are safe to get from salvage?
  17. Check a VIN?.?
  18. roof rail channel 69 cutlass S
  19. Bought me a 1983 C/S
  20. right outside mirror 67 Cutlass
  21. Shop auto to manual price?
  22. '67 Cutlass, to swap in a TH350 requires??
  23. Changing a tilt column from column shift to floor shift
  24. swap to floor shift ???'s
  25. Disc brake conversion kit
  26. 1977 brougham interior material
  27. Part wanted
  28. quarter panel extensions
  29. Converting to dual gate shifter
  30. 1980 Cutlass Supreme Transmission
  31. What goes here??
  32. Throttle cable for 68 cutlass 350 4bbl
  33. turbo 300 to TH350
  34. 71 cutalss rear wheel clearnce
  35. Power drain
  36. Finally got the C/S on the road
  37. 72 Cutlass convertible decode
  38. 1972 Fuel Tank Hoses
  39. bucket seat bracket questions
  40. Will 72 442 grille inserts fit a 1970 cutlass?
  41. Apprentice for hire
  42. Fluids for a restoration
  43. Installing windshield chrome
  44. SPID Codes
  45. Audio butchery? ... my poor doors!
  46. Switch Pitch Operations
  47. Need hood louver
  48. Sorry to say goodbye
  49. 1977 Cutlass steering column question
  50. Back window and headliner install
  51. Help with Seat ID??
  52. Winterize? No, say it isn't so!!
  53. 14" rallys with new bf goodrichs
  54. Did true 442's ever have automatics?
  55. fuel pump=electric =Quits?/
  56. 1968-1970 Cutlass Convertible Engine Options?
  57. '67 Side Trim looks Abby Normal?
  58. Daily driver routines, habits, thoughts and concerns
  59. 66 Cutlass VP400-Jetway Swap
  60. Replacing radio in 1967 Cutlass
  61. 72 Supreme window alignment
  62. interior panels on a 75 cutass
  63. Daily Driver and a 455?
  64. Numbers matching... who knew?
  65. Pic's
  66. drip rail molding
  67. Headliner for Convertible??
  68. Procar seat swap
  69. OPG first order impression... Yea!
  70. '67 442 hood? Crazy Money!
  71. column shift to floor shift
  72. Cutlass hood with louvers question
  73. 1964 cutlass f5 air cleaner needed 4 barrell
  74. Master Cylinder question
  75. Check out this 70..
  76. 65 Cutlass Convertible weight
  77. 72 Cutlass with 43k miles??
  78. 66 Cutlass cowl tag trim code question
  79. 67 Cutlass Wheel Bearing FAILURE
  80. '67 ST300 Switch Pitch mod??
  81. 1972 Cutlass S/442 cowl tag breakdown
  82. patriotic
  83. Big red
  84. 71 Cutlass Supreme cowl hood bumper question
  85. Exterior Mirror
  86. 67 c/s 2dr h.t.
  87. Proper wiper arm for Cutlass?
  88. Oldsmobile 330 Compression Test Results Good or Bad?
  89. What's the REAL temprature ?
  90. Hayden Fan Clutch 2747 Update
  91. 68 Ramrod w31 cutlass s
  92. Washer stays on
  93. 65 F-85 engine replacement
  94. Hose by radIator cap
  95. 66 vs. 67 Cutlass Convertible - What would you do?
  96. Opinions needed on Cutlass
  97. Hose clamp question
  98. 69 LeMans parts to cutlass ?
  99. 67' C/S Grill bar
  100. 65 F85 Cutlass convertible built ?
  101. Brake help Please
  102. Holy Crap. Not for those with a weak stomauch
  103. th400 tranny question
  104. Looking at replacement radiator options...
  105. Shined up the Salon for some photos (lots of pics).
  106. Any love for these?
  107. 67 c/s
  108. Peak Molding
  109. Can it be done - Daily Driver Cutlass?
  110. Is this Glade Green?
  111. Cutlass F85 shift lever for auto 2 speed jetaway
  112. vintage dealer ad
  113. Hood Height Adjustment
  114. were these stock?
  115. 1986 cutlass
  116. 70 Cutlass AC ducts?
  117. Weatherstrip channel, 1972 Cutlass Supreme
  118. Post car door compatibility?
  119. Column to floor shifter Conversion
  120. Can't Find Parts for 72
  121. Rallye 350 Piston question
  122. Rallye 350 stripes question
  123. 66 cutlass wiring
  124. 66 Cutlass A/C Vent Help
  125. Anyone in the Orange County, CA area that can check out a Cutlas for me?
  126. Computer Program for Car Maintenance
  127. Fresh air vent
  128. Help please...When will I get all the bugs out...
  129. 64 in HotRod magazine
  130. After market OAI hood for 72. What to look for?
  131. need advice and or opinion on Lojack
  132. 72 S emblems.
  133. 71 cutlass blower switch
  134. Steering wheel advice?
  135. No brake Lights
  136. Over heating and power failures
  137. Shock mount-72
  138. Blower not working
  139. Help wanted..1970 cutlass issuse's
  140. which engine to choose 455 or 350
  141. Spring - car height problem
  142. 70 engine face lift
  143. 1987 Oldsmobile Cutlass Supreme - ideas?
  144. How better to sell my car?
  145. '68 vs. '69 radiator support
  146. Cowl tag decode
  147. H/O Lightning Rods shifter cable
  148. Bumper advice
  149. Documentet production horsepower of a 1972 350v4
  150. opinions and help with 3 issues
  151. 350 diesel shortblock
  152. 1972 w-29?
  153. 68 Cutlass
  154. please help me identify my 70 cutlass
  155. Rerouting Battery Cable due to headers - 71' Cutlass S 455
  156. What is the deal with 73-75 Cutlass?
  157. Headers yes or no?
  158. 1970 cutlass question
  159. 71' Cutlass S Dash Pad removal
  160. ‘66 F85 vibration
  161. Seat belt sensor?
  162. Good Price?
  163. Rear Axle Bearing Noise
  164. How's this for price expectations?
  165. Shocks/springs package
  166. I have a crazy question
  167. 71 Cutlass Seat removal
  168. Mystery Part
  169. Starting probelms - Neutural safety switch?
  170. The old black 64 is painted!!
  171. My 70 cutlass
  172. Help with parts
  173. 1966 442 Restoration - San Diego Area
  174. 72 cutlass s cutting off
  175. Headers Question
  176. SS1 chrome wheels - I need 5 of them!
  177. 1964 Olds cutlass parts
  178. 71 cutlass tilt column shift...can it be used in floor shift car?
  179. OPG aftermarket window cranks
  180. 69 Cutlass S shroud
  181. Need pictures of quaters of a '68-'69 vert
  182. Disc Brake conversion kits
  183. 1987 Cutlass Supreme stalls in gear.
  184. Alternator Light
  185. 1964 Cutlass Ignition question
  186. 66 cutlass heater hose routing
  187. Good sale price
  188. Speedometer Gear Change
  189. Radio noise issues
  190. 70 455 Cutlass Supreme !FINSIHED!
  191. 1972 Cutlass Supreme Dyno Results
  192. "Holiday Coupe" vs "Sports Coupe"
  193. vacuum to brake booster clamps
  194. 1980-1987 Cutlass fender interchange
  195. 69 cutlass convert
  196. Backspacing to fit 10"ers out back
  197. Trying to decipher cowl tag.
  198. Parking lights painted?
  199. engine compartment color
  200. Slowly putting AC system together
  201. 77' cutlass brougham (lots of parts) in Junkyard south jersey details below
  202. New Wheels and Tires
  203. 1994 CS Convertible
  204. Wiper Refills Available
  205. 1971 Cutlass Headers
  206. Chrome dash molding
  207. what rear end ratio came in a 72 Cutlass
  208. 67 cutlass passing gear
  209. Wood grain change in dash 71 Cutlass
  210. 70 supreme random questions
  211. Does Anyone Know What Parts These Are?
  212. Rear courtesy light panel
  213. new pics!
  214. inspection cover
  215. Vintage Air Conditioning
  216. 1970 W31 questions
  217. Fuel/vapour lines help
  218. 68 Olds Cutlass ??? W-31
  219. semi- crushed puck?
  220. 70 inners eh?
  221. Spark plug wire retainer clips and brackets
  222. To Post Or Not
  223. Alternator date stamp acceptable range
  224. dipstick tube
  225. 72 cutlass S question
  226. Steering shaft specs - '72 Cutlass
  227. rear main seal
  228. timing chain cover gasket
  229. 1970 W31 authentication
  230. timing chain parts
  231. 70 ball joints?
  232. Lowering spindles and springs
  233. Cold Air Intake
  234. Is this backspace difference too much for a replacement wheel?
  235. engine paint
  236. 67 cutlass basket case?
  237. 85 3.8 cutlass swappable parts?
  238. 1968 Cutlass - Stock Fan Blade Diameter?
  239. timing chain play
  240. Opinions needed on 72 Cutlass
  241. check it out....
  242. 84 Brougham or 84 Calais
  243. 64 cutlass air cleaner retainer plate
  244. What does it weigh?
  245. 67 Post Trim Removal?
  246. my 66 cutlass
  247. Youtube
  248. ...and
  249. Just a few pics....
  250. dual exhaust
