65 F-85 engine replacement
Old Jul 29, 2012 | 10:25 PM
1965F85_scholten's Avatar
I am thinking about replacing my original 330 ci engine with a big block. Which engine is the closest to being able to drop right in without the mess of the motor mounts, bolt patterns, etc of a non-matching. From what I can tell a 400 should do the job if I can find one.
Old Jul 30, 2012 | 02:49 AM
66luvr's Avatar
https://classicoldsmobile.com/forums...330-455-a.html
Old Jul 30, 2012 | 07:12 AM
All of them bolt in. All BBO motors are externally identical, so 400, 425, 455 are all the same. Use the ORIGINAL motor mounts for the 330 (Anchor P/N 2261). DO NOT get "455" motor mounts. Use the 69-72 W/Z exhaust manifolds. Use the water pump, accessory brackets, and pulleys from the 330 as a matched set. All the accessory brackets will bolt to the BBO (there are two sets of mounting holes in the brackets if needed). Get a bigger radiator. Start saving for a TH400 when the Junkaway pukes. Start saving for new rear tires.
Bluedane
Dec 9, 2018 01:17 PM
BlueLouToo
Non-Olds Engines
Aug 26, 2014 04:24 AM
805cut
May 3, 2012 08:11 PM
Olds luvr
Mar 17, 2010 06:57 PM
m_tanner_75
Dec 28, 2008 02:06 PM
