timing chain cover gasket
What do you mean not even close? The cover itself slides on 2 dowel pins. These must be clean so cover goes all the way on. The gasket itself is paper thin and should need no rtv but a little high tack or the like can be used.
I clean the surface, put a thin layer of RTV down (spread with my finger) put the gasket on, then spread a thin layer on top of the gasket, then put cover on.
This is the way I've been doing my gaskets, and I haven't had a problem
dallasite21
Jun 20, 2010 05:37 AM
