timing chain cover gasket
Old Feb 15, 2012 | 09:12 AM
jdiggitydogg's Avatar
got a fel-pro engine gasket set timing cover gasket not even close. should i just use rtv? is there a gasket that would work
Old Feb 15, 2012 | 09:28 AM
Which engine and which gasket? Never had a problem with FelPro gaskets.
Old Feb 15, 2012 | 09:30 AM
Oldsmaniac's Avatar
What do you mean not even close? The cover itself slides on 2 dowel pins. These must be clean so cover goes all the way on. The gasket itself is paper thin and should need no rtv but a little high tack or the like can be used.
Old Feb 15, 2012 | 11:16 AM
i am an idiot wasnt paying attention put it on cover matched fine. ive never had problem with fel-pro either thanks though
Old Feb 15, 2012 | 11:21 AM
Redog's Avatar
I clean the surface, put a thin layer of RTV down (spread with my finger) put the gasket on, then spread a thin layer on top of the gasket, then put cover on.
This is the way I've been doing my gaskets, and I haven't had a problem
navvet
Mar 14, 2015 05:45 PM
72OLDS-EH
Jul 5, 2010 05:00 PM
dallasite21
Jun 20, 2010 05:37 AM
crazy'boutOlds
Aug 6, 2009 05:40 AM
sklbndt
Apr 15, 2009 04:34 PM
