Replacing timing chain cover gasket...WARNINGS?
Old Mar 14, 2015 | 04:26 PM
navvet's Avatar
The timing chain cover gasket on my 64 dynamic 88 w/AC needs replacement.
I have been reading up on the process and it notes I have to tilt/lift engine to gain access. Question: what concern should I have with the tranny and do I have to drop tranny..A lot of work for a $10.00 gasket but needs to get .
Any directives would be appreciated.
Old Mar 14, 2015 | 05:45 PM
Oldskeeper's Avatar
Hi Navvet, what I would do is undo the front mount and place a piece of wood on the pan and lift it up enough to shim underneath with a piece of wood as to spread the weight out over and not push the pan in.The drive shaft stay's in and the transmission will go as high as the fire wall and this will give you the clearance you need. If you push the pan in the crank shaft will hit it (ask me how I know) then you can remove the timing chain cover, I would also do the water pump and rebuild the fuel pump to take the crappy gas while it's off and replace the front crankshaft seal. I'm pulling the engine out of my 63 98 custom sport coupe next week to replace the seals and gaskets.
Steve
http
Apr 26, 2013 09:58 AM
jdiggitydogg
Feb 15, 2012 11:21 AM
dallasite21
Jun 20, 2010 05:37 AM
crazy'boutOlds
Aug 6, 2009 05:40 AM
sklbndt
Apr 15, 2009 04:34 PM
