Finally got the C/S on the road
Old Nov 22, 2012 | 10:54 AM
67Olds442X2's Avatar
Navy P-3 FE (Ret.)
After picking up this car months ago, finally got it road worthy. Had to repair the windshield channel and then install a new windshield. Also did some tune up work on the motor which I believe hasn't been out of the car ever, 180k miles later. Seems to run pretty well considering the mileage. The only other major things that will need attention are the body mounts. The front four and the two most rearward are the only ones intact per se. The rest are rusted away
Old Nov 22, 2012 | 11:31 AM
Beautiful looking car. Just don't corner so sharp or the body will fall off the rustout points. I'm not that surprised that the engine was original even at 180K. They were solid performers.
Old Nov 22, 2012 | 12:03 PM
White_Knuckles's Avatar
Oh man, that looks like a Bad Boy with the dual carb high rise! I bet she scoots when dialed in. What motor is that? 400?
Old Nov 22, 2012 | 02:29 PM
Navy P-3 FE (Ret.)
It's a 455 .030 over and unfortunately haven't had it running long enough to check it out. Had a valve guide loosen up and a lifter that failed wrecking the cam. Will be build differently next year sometime.
Old Nov 22, 2012 | 10:48 PM
Sweet. She looks like a Mad-Max escape car when the big one hits!!
Old Nov 23, 2012 | 10:03 AM
Well I'm glad you quit dragging your feet on that one, LOL. Seriously it is a sweet rig. The body mounts will probably be a challange. They are a pain even on rust free cars.
Old Nov 24, 2012 | 07:22 AM
oldsca's Avatar
Crazy Canuck
Nice ride. She looks beautiful!
Old Nov 24, 2012 | 08:30 AM
Navy P-3 FE (Ret.)
Thanks for all the comments and yes "oldcutlass" I was dragging my feet for sure. I think I was almost scared to do the windshield install and it actually was not too bad to do. The first time I was off a little and had to remove it and try it again. The trim was the hardest to do.
Old Nov 24, 2012 | 09:27 AM
I hate windshields, I've cracked my share. Glad you got r done.
Old Dec 7, 2012 | 06:57 PM
old80cs's Avatar
Beautiful Cutlass, liking the black top and burgundy paint! Too bad about the body mounts being rotted, been there done that with my 1980 CS. The 4 rear mounts on mine weren't there anymore, so I had a Monte Carlo cut up for good replacements. It donated a complete floor pan as well. Take care...
Jeff K.
Jul 11, 2014 08:43 AM
StickW31
Jun 21, 2012 03:52 AM
cutlassjoe
Sep 19, 2011 09:23 AM
65az
Oct 31, 2009 09:47 AM
65az
Oct 27, 2009 08:50 AM
