Fresh air vent
Fresh air vent
1972 Cutlass convertible with A/C. When I put the control on VENT and turn the fan on, very hot air comes out of the vents, even on cool days. the temp control is all the way to the left on cool.
The heat, A/C and defroster all work as they should and the cool to hot control on the dash works fine.
Any ideas about this hot air coming through the vents?
It's a vacuum valve screwed into a hole in the passenger side rear of the intake manifold.
It turns off the flow of water to the heater core when you select "High Cool" or push the temp. lever all the way to the coldest position.
Also on the shelf or one day away at your local auto parts store.
(Note that there are a few variations for different years and models - some close when vacuum is applied, others open.)
84oldsDelta88
20
January 12th, 2016 01:36 PM
December 10th, 2011 07:49 AM
