Chrome dash molding
Old Mar 2, 2012 | 05:26 PM
71cutlass_ragtop's Avatar
Chrome dash molding
Anyone know where I can find a replacement chrome dash bead molding for a 71 cutlass supreme? I've checked opg and ebay... Not sure where else to check
By the way, I'm a new guy on the block... I recently bought this 71 and she needs a little touching up...
Thanks for the help!
Old Mar 2, 2012 | 05:31 PM
69'442's Avatar
Check Fusick. They also sell it on ebay. Try here.
http://www.ebay.com/itm/1970-72-Olds...item231a8384a9
Old Mar 2, 2012 | 07:50 PM
Lady72nRob71's Avatar
Originally Posted by 69'442
Check Fusick.
X2 - I got the bead for my 72 from there.
BTW, WELCOME!
Old Mar 2, 2012 | 07:56 PM
Don't forget Parts Place - same molding, same great price 39.00
Part number IN3148T
(1970 - 1972 Cutlass/442) DASH BEAD MOLDING WITH CLIPS - MOLDED JUST LIKE FACTORY WITH CHROME PLATING
Use 'dash bead molding' as the keyword search http://www.thepartsplaceinc.com/ocat...&YearList=1972
Old Apr 21, 2014 | 09:40 PM
dwtucker's Avatar
Chrome dash molding/Bead
I have a new one from Fusick, but how do you get the old one out?
Old Mar 21, 2019 | 07:01 AM
Originally Posted by Allan R
Part number IN3148T
The correct part number is: IN3418T
Old Mar 21, 2019 | 01:51 PM
11971four4two's Avatar
MOTORHEAD
GM Part Number 231289
Old Mar 21, 2019 | 03:44 PM
442Harv's Avatar
Take a flat putty knife, or plastic trim remover tool. It may be glued on, or have the little barbed pins, that slide on the back of strip. The clips are so much easier, but do put holes in dash. May have to slide pins a little, so not in old hole.
Old Mar 21, 2019 | 05:03 PM
72455's Avatar
1972 U code Supreme
FWIW, when I replaced the dash bead in my '72, I used the existing holes and it worked fine.
Old Mar 22, 2019 | 04:27 AM
This thread is from 2012...
Old Mar 22, 2019 | 05:06 PM
MOTORHEAD
Old thread
Info "good"
kroozit69
Mar 26, 2014 07:45 PM
David Lidenberg
Jul 14, 2013 09:16 PM
Chris Schoff
Body work
Jun 30, 2013 05:51 PM
Alex72cutty
Oct 9, 2012 12:18 AM
Aceshigh
Jul 1, 2009 12:13 PM
