Lowering spindles and springs
Old Feb 12, 2012 | 08:09 PM
highschoololds's Avatar
I have a 71 Cutlass S. 350/auto. Looking to get 2 inch drop spindles, stock height front springs and 1 inch lowering rear springs. Are there any preferences of manufacturer or retail location?
Thank You!
Old Feb 13, 2012 | 07:46 AM
oddball's Avatar
Take a look at some of the info on the ATS AFX spindles. It appears the 2" drop spindles cause more sever bump steer and other geometry problems. But it all depends on how you drive and what you expect.
One indicator is to look for spindles that still use the bolt-on steering arms. The cast-on arms tend to be in worse positions.
Depending on the drop you want, a combination of tall lower ball joints plus moderate spring drop can get you there, and get better geometry.
Old Feb 13, 2012 | 08:13 AM
gearheads78's Avatar
car guy
The advise above is dead on. A good alterantive if you don't want to spring for the AFX is the stage II+ kit that comes with Howe circle track style tall ball joints. Both are sold by the same company SC&C. I used the StageII + on my old 66 cutlass build.
johnnywu
Oct 28, 2013 03:37 PM
Murco
Brakes/Hydraulic Systems
Mar 7, 2013 11:50 AM
rogiestone
Oct 18, 2011 06:11 PM
DAN76
Oct 10, 2008 05:52 AM
eddiem06
Dec 24, 2006 08:06 PM
