PDA
View Full Version : Other Oldsmobiles
Pages : [1] 2 3
  1. 65 Starfire bumpers
  2. 1966 Starfire drum brakes
  3. Steering wheel medallion removal
  4. 1967 Delmont air cleaner element
  5. Debating purchasing this
  6. 65 Starfire temp gauge
  7. ‘74 455 Omega Serpentine question
  8. She's a beauty!
  9. 1983 Cutlass Ciera Brougham 2-D Coupe
  10. Spindle speedometer cable restoration howto
  11. 1961 olds f85 wagon w/factory air
  12. Disappearing timing marks?
  13. 1966 Starfire exhaust questions
  14. 1966 Starfire: Firewall question
  15. 1966 Starfire dual master cylinder conversion
  16. Can’t find sending unit for 73 omega, help!
  17. Steering / Suspension Parts 1980 Oldsmobile Omega Brougham 2.5 L 151 CID L4 (4 Door)
  18. 1973 oldsmobile omega vacuum line diagram?
  19. 73 omega heads?
  20. 73 omega stalling under load
  21. 73 olds omega a/c delete but want to retain heat
  22. Frame Question
  23. Wanted: Engine vacuum diagram for 66 Starfire
  24. New owner of 66 starfire
  25. 1964 Super 88 vin help
  26. Cornering lights on a 64 Starfire
  27. Correct engine color for a 64 Starfire
  28. BT-33-2 Measurements?
  29. 85 Custom Cutlass/El Camino
  30. 1957 Golden Rocket
  31. Brake conversion kit
  32. 1962 Olds Starfire Standard/Optional Equipment Listing
  33. Drive shaft bearing
  34. JetFire
  35. Roto 5 TV Adjustment
  36. 1964 Olds Starfire Cnvt---What options?
  37. Olds Engine Identification Help
  38. 62 rear seat hold down brackets
  39. Jetstar 88 Brake booster
  40. 1963 oldsmobile F85
  41. Oldsmobile omega 1974
  42. Back with a 62 Cutlass
  43. 63 cutlass roto 5 trans issue
  44. 63 Oldsmobile Starfire Convertible emblem
  45. Aftermarket Grill for 73 Omega
  46. Emergency brake assembly
  47. 63 f85 gas tank noises
  48. An Omega SX in the wild
  49. 62 starfire exhuast manifolds
  50. 62 starfire gas pedal return spring
  51. '64 Starfire Convertible
  52. Update on 62 Starfire ventilation vacuum control panel
  53. Does anyone know anything about this 87 firenza hatch?
  54. Oldsmobile F85 with rochester 2GC carb
  55. 66 Starfire options list / pricing
  56. The Continuing Saga of "Blue Cheese" - '63 Cutlass
  57. 1962 Olds Starfire Scrapyard Find - wheel needed
  58. 79 omega tie rod question
  59. "1963 Oldsmobile F-85 Deluxe" - Refresh & Build Begins...
  60. 64 starfire water pump
  61. "1963 Oldsmobile F-85 Deluxe" - Cowl Tag Decode Help Please...
  62. 64 jetstar1 rear tire/wheel fit up
  63. Resonators and Exhaust spec's for '64 Starfire
  64. correct size 63 Starfire battery
  65. 62 Starfire Wheel Covers
  66. 63 starfire molding clips
  67. 1964 starfire floor pans
  68. Starfire 64 progress and questions
  69. 1973/74 Omega: 442 w30 lookalike hood
  70. 1965 Olds Starfire - Data Plate Decipher
  71. 1965 Olds Starfire Standard/Optional Equipment Listing
  72. 1963 Cutlass Survivor - Gentle Restoration and Mild Hop Up
  73. Boat guys welcome?
  74. Don't have a car yet... but!! making a plan. '63 F85
  75. 66 Starfire steer column lower bearing
  76. Omega sub frame connector brand suggestions
  77. The fleet has grown 1986 Calais Coupe
  78. El cutlassino w30
  79. 65 Starfire Fuel Tank
  80. 79 omega 307 backfires when letting off throttle while driving
  81. 1978 Oldsmobile Omega SX Brougham
  82. 64 SF Kick Panels
  83. Compression psi ?
  84. 62 Olds Starfire windshield.
  85. starfire steering column
  86. 1981 omega steering fluid
  87. 1961 f85 Ebrake lever return spring
  88. 305/350 headers on a 307 will it work
  89. f85 condenser question
  90. Rochester 4GC - '63 F-85
  91. The Ninth Generation Eighty Eight 1986 - 1991
  92. Assistance with cowl tag decoding
  93. 79 Omega body tag decode help
  94. 63 f85 horn bar
  95. RH mirror on a 63 F85
  96. 79 omega 231 bogging and bad skip under throttle
  97. 66 Starfire Radiator
  98. 1961 f85 under hood/trunk light
  99. 1961 f85 front body parts and seal
  100. Leaf spring interchange 79 omega 2dr
  101. Head bolts for 79 Omega 3.8
  102. anyone have a gmc motorhome
  103. 1961 f85 insulator and gasket
  104. '64 S/F Wheel Disks, Custom (P03)
  105. 1963 f85 steering wheel
  106. '62 F85 convertible questions.
  107. 62 starfire engine/tranny info needed
  108. 1961 f85 rear brake shoe
  109. 1961 f85 conversion generator to alternator
  110. PCV Setup 64 Starfire
  111. 1962-1963 F-85 seats
  112. 65 starfire rear,
  113. 1934 reo
  114. 61 f85 oil pump cover Thrust Plate
  115. 64 starfire Jack Storage
  116. corrosion on engine 1961 f 85
  117. 1961 f85 radiator
  118. 1961 f85 drive gear distributor
  119. 1963 Cutlass/f85 for sale, NOT MINE, anyone know the car?
  120. 63 F85 control arm bushings.
  121. 64 Starfire grille & extensions
  122. '63 F-85 Brake Question
  123. steering gear on 1963 f85
  124. 1961 f85 expansion tank overflow
  125. 1961 f85 accessories
  126. F-85 Grille Material
  127. 78 Omega Sheet Metal
  128. Mileage tracker
  129. 63 f85 convertible cylinders and pump install
  130. starter drive wanted
  131. Omega help needed
  132. 1961 f85 heater control valve rebuilding
  133. '64 SF Heater Box
  134. 61 f85 oil filter reference
  135. 64 Starfire - really hot console
  136. 61 f85 heater valve
  137. 1985 Ciera Indy 500 "Princess Pace Car"
  138. 1964 Olds 394 Vacuum advance
  139. 1961 f85 " how to " questions
  140. '63 F85 interior question
  141. 191 f85 timing cover seal
  142. 1961 f85 timing tools
  143. 61 f85 right exhaust manifold
  144. 61 f85 power steering hoses
  145. Can anybody identify this part?
  146. Thought I would share this recent purchase.
  147. 63 Starfire engine swap
  148. 64 starfire main window run channel weatherstrip
  149. Delta 88 and 73 Omega quetion
  150. Fixes for seal on heater valve
  151. Source for 62 Cutlass Differential cover
  152. '63 Oldsmobile J-TR
  153. 64 Starfire aftermarket audio!!
  154. 62 starfire conv
  155. Starfire forum?
  156. 1962 Starfire carburetor identification
  157. 1962 Starfire windshields
  158. Well I bought another 63 F-85
  159. 1965 Starfire motor mounts
  160. 63-f85 transmission leaks
  161. 1964 Starfire floorpans (whats close)
  162. Hub driven speedometer cable - starfire
  163. 63 F-85 deluxe Back on the road--leakin
  164. 63' F-85 wheel and tire selection
  165. '64 P. Brake booster finish
  166. Chin spoiler pic needed - '64 S/F
  167. 62’ Cutlass trim removal
  168. 74 omega big block headers
  169. 1961 f 85 engine gaskets
  170. Starfire exhaust system
  171. 62' Starfire ear end
  172. 62 starfire
  173. 62 starfire
  174. 1961 starfire front emblem bar
  175. Kustom Olds video
  176. 64 Starfire air cleaner colors
  177. 64 Starfire washer bottle location?
  178. 64 Starfire VIN
  179. 64 Starfire speedo
  180. 1974 Omega
  181. 64 Starfire w/455 headers
  182. Rear control arms 62 Starfire convertible
  183. Newby 62 starfire conv
  184. Anybody make Rocker panels for the '62 F-85?
  185. 1965 Starfire 4-Speed, Is It Original?
  186. 1965 Oldsmobile transmission support brackets
  187. 1966 Starfire value
  188. Help me ID my Dad's Car?
  189. Jetfire block vs f85/cutlass block
  190. 61 Starfire
  191. 65 starfire wheel question
  192. 1963 F85 Wagon rear hatch striker assembly
  193. Bob needs floor boards, 65 Starfire
  194. 63 F85 Distributor
  195. U-Joint Bolts/Girdle
  196. Oil dipstick
  197. 62 vs 65
  198. Oldsmobile Golden Rocket
  199. 1961-63 Starfire rocker clips
  200. Rover Engine in an '62 F-85 Cutlass
  201. 215 V8 Water pump pulley
  202. 61 f85 rivet vent fornt door
  203. 61 f85 rubber door questions
  204. 64 starfire AC control
  205. 1961 f85 delco shocks information
  206. Don't know what this is for!
  207. Hood Question
  208. 1965 Starfire exhaust
  209. 1965 Starfire 4 Speed Convertible
  210. 1961 f85 fuel lines information
  211. '62 Cutlass Fuel tank sending unit
  212. '62 Starfire vacuum cannister
  213. 64 Starfire twins
  214. 1961 Starfire Holiday Hardtop
  215. oil for F85 1961 ??
  216. 61/62 Starfire question...
  217. 65 Vista Cruiser Fuel Tank
  218. 1962 cutlass Generator
  219. 62 starfire rear coil springs
  220. 1961 F85 Exhaust system
  221. 1963 Cutlass rear shock part #
  222. '74 Omega Problems
  223. Eventual trans replace in Starfire
  224. 65 F85 Bench Seat cover - can't find!
  225. 62 Cutlass Aftermarket Radiator
  226. Post or hardtop. ??? F85
  227. 63 cutlass steering wheel question
  228. 1970 Rallye 350
  229. 63 Cutlass trans and more advice.
  230. 1962 Starfire Master Cyl/Booster Update Question
  231. 63 F-85 underhood color & cowl tag decode
  232. 64 Starfire grill - red or no?
  233. Fluid help for the 215v8
  234. Need some help making the right engine/trans choice on my 63 F-85
  235. 215 v8 question
  236. 65 starfire
  237. Dumb question about 62 Olds full size 394 fuel pump
  238. 62' cutlass fuel sending unit
  239. Jetfire
  240. 66 Starfire Fuel Pump
  241. Trying to find out if my Olds is rare or common
  242. 61 Starfire - what do i have?
  243. 61 f85 fuel lines/tank
  244. Jetstar 88 spindle
  245. Major fuel issues
  246. 65 starfire
  247. 1962 cutlass
  248. Bumper tuck
  249. 62' wagon
  250. For a 1962 cutlass
