Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
61 f85 right exhaust manifold
Old Aug 19, 2018 | 08:28 AM
Guillaume's Avatar
Hi , i would like to know what is the function about the "little box" on the right exhaust manifold ?
Thanks for your time
Guillaume
Old Aug 19, 2018 | 09:02 AM
jensenracing77's Avatar
I don't have much experience with the Non turbo setup but I believe that has to do with the hot air pipe to the choke? The hot air pipe is on the other side for the turbo setup.
Old Aug 19, 2018 | 09:14 AM
Guillaume's Avatar
thanks for your reply but the hot air for choke is at the middle of the manifold so i am thinking this another application but for what ???
Old Aug 19, 2018 | 12:09 PM
I don't know what intake manifold you have, but Eric is correct. The box on the manifold is the hot air stove for the choke. There should be a small diameter metal pipe from that box to the choke coil housing on the carb. The stock intake on the 215 does not have an exhaust crossover, so there is no way for hot exhaust to provide any heat for the choke from the intake manifold. There is a hot water passage under the carb, but that does not provide heat to operate the choke.
Will22
Jun 26, 2019 11:16 AM
rocketcouple
Jan 31, 2018 10:59 AM
poodlefire
Aug 4, 2017 02:21 PM
stephenca118
Mar 16, 2017 06:24 AM
wally74
May 18, 2011 07:20 PM
