Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
66 Starfire Fuel Pump
Old Dec 12, 2016 | 02:29 PM
lucasstarfire00's Avatar
Lucas H.
Ok so my 66 Starfire has a rusty tank. We cleaned it before, and then began to use it. Well guess what, it wasn't clean enough. It pulled rust from the tank and clogged the carb. We are working on redoing the tank and carb, but my mind turned to whether or not the fuel pump also got hurt from rust. If I were to replace it with a regular old mechanical fuel pump where should I go? I use rock auto for most of what I've needed so far but I would like a delco or delphi fuel pump, not a crappy chinese one...
Old Dec 12, 2016 | 02:55 PM
m371961's Avatar
Did you have a sock on the fuel pickup? Your fuel filter did not stop it before the carb?
Old Dec 12, 2016 | 03:37 PM
66-3X2 442's Avatar
Carter makes a nice pump if your car uses a return line. The part # I use is
M4516 & I use it on my 66 442 3X2 car. It has the correct fitting/line placements for my car and I bet it will be the same for a Starfire. It's ethanol compatible also.
Old Dec 12, 2016 | 04:21 PM
therobski's Avatar
How's the fuel line?? That can also cause head aches.......
Old Dec 12, 2016 | 05:10 PM
Lucas H.
I'm not sure on the sock but I'm running a filter in the line right before the carb that is visible and the fuel came out pretty cruddy. I guess it wasn't enough
Old Dec 12, 2016 | 05:11 PM
Lucas H.
I'll have to look in to that one more, thanks.
Old Dec 12, 2016 | 05:13 PM
Lucas H.
Probably not too good. Once the tank is refinished I might as well replace the line.
Old Dec 15, 2016 | 05:18 PM
Lucas H.
On rockauto for the 66 delta 88 425 it lists a carter m4871 and also the m4516 you talked about. The difference seems to be that the m4871 is a non-ac part, and my car is non ac so would this be the better choice? I think they're largely the same
Old Dec 15, 2016 | 06:23 PM
66-3X2 442's Avatar
The non A/C unit probably doesn't have the return line and if your car doesn't have a return line,that's probably the correct one.
RenderPit
Ninety-Eight
Aug 6, 2015 04:55 PM
mefirst72
Feb 10, 2013 06:37 PM
Nor Cal Andy
Mar 29, 2012 07:27 PM
stlbluesbrother
Mar 21, 2011 03:24 PM
sshriber
Mar 22, 2010 06:16 PM
