Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
1961 f85 " how to " questions
Old Aug 21, 2018 | 03:28 PM
Guillaume's Avatar
Hi , i would like to remove timing cover but i don't know how to hold the crankshaft pulley to remove it ?? and i would like to know how to remove oil pan after all screws are removed ?
Thanks for your time
Guillaume
Old Sep 13, 2018 | 01:47 AM
Guillaume's Avatar
no one has already removed the damper pulleu to change the timing cover seal ?? i just need to know if i must put a speed on my automatic transmission or use a special tool to hold the flywheel or other ??
thanks
Old Sep 13, 2018 | 07:02 AM
You need a flywheel holder (also called a flywheel turner) to keep the engine from spinning. This engages the teeth on the ring gear. Usually it requires two people - one to hold the flywheel and one to deal with the balancer. You can try removing the starter. Sometimes you can insert a rod or screwdriver into a hole in the flywheel and lock it up against the block.
Old Oct 4, 2018 | 11:48 AM
Guillaume's Avatar
Thanks for your help Joe but i can use the tool you are talking about because the bellhousing on my hydramatic transmission is all around the flywheel . the only one way i could use is a tool to hold the balancer pulley . is it possible to do it like that ? no problem for the balancer pulley if i take this way ?
Old Oct 4, 2018 | 12:08 PM
No problem holding the balancer, but you can also try pulling the starter and using a pry bar or long screwdriver to hold the flywheel.
Old Oct 4, 2018 | 12:13 PM
Guillaume's Avatar
ok Joe , i will try these differents ways too, thanks for your time
maddoctor
May 21, 2018 05:37 AM
Oldsragger
Jun 15, 2015 04:33 AM
Octania
Nov 15, 2013 07:30 PM
Olds Scott
Sep 2, 2013 07:48 AM
Stevec
Mar 24, 2012 10:18 AM
