65 starfire
65 starfire
hi all, was looking for some input on what would be a good intake and carb, for an up grade ,I really like the qaudrajet carbs, but it seems like I would have to go with a 66 starfire intake to acomplish this. also would this improve my performance, or do you think I am wasting my time,that I am good where I am , thanks very much for the help in this subject , will.
Don't rule out a Holley, especially if you put an aftermarket intake in your Starfire. It's just like asking an opinion on what motor oil to use, every one has different thoughts.
FWIW, I run a Summit 750 cfm carburetor on my 455. It's a clone of a Holley 4010 (which is actually a clone of a Motorcraft 4100). They are cheaper than a Street Avenger or Performer but still use Holley parts.
https://www.summitracing.com/parts/s...50vs/overview/
Personally I find Holley (and Holley clone) carbs to be good W.O.T. carbs for building horsepower but their low speed performance pales in comparison to the E-brock and definitely the Qjet. The latter two carbs are much more sophisticated and have a much more precise primary metering system. This added complexity is why they can be more difficult to rebuild and set up properly, but there are definite rewards if you take the time to do it right, especially on a heavy, street driven car.
I had an Edelbrock Performer for a short while on my 64 98 and it worked straight out of the box with virtually no tinkering. It was very streetable. The Slim Jim was just a POS even when the throttle valve was setup correctly.
Oldsguy had a Holley double pumper on his 69 Delta 88 for awhile. We could never get it to run quite right, even after a rebuild. I think we went back to a Q-jet.
All that being said I still like my Summit carb. One of these days I might swap for an EFI system.
Possibly the worst Holley choice for a heavy full size. If one MUST have a Holley, at least use a vac secondary carb in this application.
Kyle's 77 Cutlass
Jan 1, 2014 09:06 AM
Oldssupreme
Feb 3, 2013 06:26 AM
Oldssupreme
Feb 3, 2013 06:24 AM
