- Omega info
- 1996 Cutlass Ciera 2.2 engine woes
- Rear Drum Brakes
- 66 starfire suspension question
- Electric Fan on Stock Radiator 62 Cutlass
- 63 Cutlass Rear Control Arm Bushings?
- Front end question for the 62 Cutlass
- 64 f-85 ignition key
- 1962 cutlass f85
- Rallye 350 Tach
- Decent progress, 66 Starfire is officially running
- 1962 cutlass parts
- Carb jets and replacement muffler
- Frames
- 63 Cutlass engine issues
- 1965 Starfire with a 4 speed!
- 1962 Olds Jetfire available
- Windshield and Dashpad for 62 Starfire?
- 1963 Cutlass resistor wire
- Upper Ball Joints - 63 Cutlass
- 61-63 F85, Dealer Install A/C Installation Instructions
- Eric's Jetfire Turbo 4 speed
- 63 Cutlass trans kickdown and other trim items
- '61 cutlass floor pans
- 1963 Jetfire with turbo
- Electric Water Pump on 215 V8?
- 65 Starfire Suspension
- 1974 350 rocket ac and brackets
- Convertible top question
- Interchangeable parts
- 62 olds a/c electrical swiches
- 62 cutlas gas tank replaced with 70 Nova tank
- source for the 61-63 cutlass Tan trunk mat material
- 65 olds starfire
- Money saving tip for 61-63 F85s.....
- in need of a turn signal switch for a 62 f-85
- 1962 F-85 Heater core
- Need a favor from 61-63 f-85, cutlass owner
- 1962 F-85 Cutlass factory 4-speed clutch question
- Engine Stalls on Hard Braking
- Manifold heat wrap for 63 Olds Cutlass?
- Center Link Bad Ball Joint
- Pob #3 sealant for front cover? 63 Cutlass
- 61-63 cutlass rear end swap
- 1963 Cutlass trans mount height?
- Molding clips for 1961 Starfire
- 1961 Starfire Ornament trim
- 62 starfire
- 62 Cutlass Steering Pump Cap
- Correct engine ?
- 1962 Cutlass Convertible - OEM Wheels
- 62 starfire heater valve and mounting bracket
- 1963 Starfire Jack Installation
- Original???? Yeah sure
- 63 Cutlass Air Conditioning Compressor?
- New Member with 215 V8 Sprite and Question
- 1964 vista cruiser questions
- 700r4 kit for my 63 starfire
- 62 starfire gas tank
- 1965 Starfire Gas line/Fuel tank questions
- Olds/Buick 215 V8 flywheel questions....
- 63 F-85 project kickoff
- 63 Cutlass transmission filter installation?
- 66 starfire heater core - fender removal?
- for 73 omega: want to find appropriate choke pull off and get sanity check
- 65 Starfire Convertible spotted in NY!
- convertible top question
- 62 starfire under dash vent cover
- Runs like a NEW car!
- carb upgrade for a 66 starfire 425?? help?
- parts question for 65 starfire
- Need help finding a part!!
- 65 425 air conditioning info needed
- Frame swap
- pics of my 66 starfire
- Steering wheel interchange
- Rochester 2nd carb
- Newbie with a pair of 65 Starfires
- funny thing about the olds
- interior question
- f85 seats???
- f85 fluids
- Oldsmobile Dealer Invoice F85 Town Sedan
- 79 omega
- Any tips for changing intake manifold gasket on my 62 Starfire
- 61 f-85 carb and lifter questions....
- Motor mount pics
- 61-63 f85 cutlass dual reservoir master cylinder conversion
- well got another 66 starfire
- MOTOR MOUNT1978 oldsmobile omega 350 rocket
- intake cleanup
- 63 Cutlass master cylinder
- '64 Olds Starfire convertibles
- 63 Cutlass HELP! distributor/timing?
- Omega tail light bezels
- Quick Question
- 1963 Full Size Olds Disc Brake Conversion
- 63 Cutlass - several questions
- 1964 olds (not mine)
- 1978 omega brougham
- 61 starfire top
- 197? Olds omega
- 1963 Starfire passenger rear quarter patch panel needed
- Need Advice on 2GC Carb Rebuild
- 1963 STARFIRE parts interchange help?
- 1962 convertable rear seat Upholstery
- 61 f85. can you bore it?
- 62 starfire aluminum panels
- '64 Jetstar 88 suspension
- Oldsmobile f-85 1961 Back glass rubber
- Five 1963 F85 Parts cars and Convertible
- Spark Plugs F85
- Heater Core? Noise, 1978 Starfire
- 65cutlassf85 driver
- cheap starter rebuild .thought id tell you guys
- where do i find a 5.0?
- spindle nut torque
- Inside heater control
- 62 starfire console
- 1975-1979 Omega Headers Options
- Big Block Omega Headers
- Stock Transmission Question-Omega
- Picked up a 62 Starfire
- New Omega owner. 1978 Omega SX
- Anyone hiding one?
- 78' Omega
- 1972 F85 Cutlass spares in Seattle area
- 1986 Olds Calis 2.5 liter
- 1963 Starfire shifter button issue
- Omega front clip
- Classic Auto Restorer Magazine '62 Starfire
- Difference
- Help me - what is this part?
- How to remove the instrument cluster and radio 62 Starfire?
- 1962 F 85, will a 455 big block work?
- 62 starfire thermostat housing
- My 1974 Olds Omega
- 63 f85
- Drivers Side Lower Control Arm for a 63 F85
- Upgrading my 1963 Olds Starfire.
- engine color
- 1974 Olds Omega S production
- Advice on a 1962 Starfire?
- Temp sending unit/switch
- setting windshield 65 starfire
- back seat
- 74 Omega Hatchback lifts For Sale
- Brake conversion for 62 Starfire
- 62 Starfire ragtop
- winshield?
- need hubcaps?
- 64 Starfire Tilt Steering Column
- preesure hose
- Results of my 4GC carb rebuild part 2
- Rim Choices
- Carb inlet fittings and filter info
- Ok... the results of my 4GC rebuild..
- door windows
- Well I rebuilt my 62 4GC 4 Jet carb..
- Underhood color questions 62 Starfire
- Headlight Switch
- Console light
- 64 starfire data plate questions
- 1978 Starfire sx
- Wiring Dia.
- '63 F-85 convertible motor mounts keep ripping
- 1973 Omega Parts for sale
- part #s
- 65 Starfire Oil Pan Tool
- '63 F-85 questions
- Wheel covers/hub caps
- Need help locating windshield trim/alternative.
- 62 Olds at Indy
- Some 62 olds options questions (rear defroster & trunk release)
- Modern Carbs
- Windshield wiper arms
- Omega Grills
- '63 F-85 flywheel
- 64 Olds Starfire
- 1962 Oldsmobile Starfire Convertible
- offy 360 dualquad highrise into '69 455 HO
- Power antenna switch
- 62 Starfire sits crooked?
- 65 starfire project for Dad finally done
- 61 f85 .brake booster or assist??
- 66 Starfire frame
- f85 carb problem?
- New look Omega
- 62 Cutlass F85 Wheels?
- chrome trim removal
- 62 Starfire Air Filter
- Heater Hoses
- Starfire parts...Profit opportunity?
- Wheels
- engine brakets,
- Looking for a good starfire tune up book/carb book
- Favor from a fellow Omega owner plz!! :)
- 1973 Omega
- Roof pillar emblems
- How to remove clock handle to change gauge glass
- Spark
- New Leaf Springs, Weird Sound??
- Official? big block Omega thread :)
- 65 Starfire sending unit
- 1983 Olds Omega Transmission Rebuild?
- 1973 Oldsmobile Omega Stero???
- Decided to sell
- What I posted on Craigslist
- Olds 215 Oil Pressure Extremely high?
- an idea of this cars value ?
- Omega owners unit! (HELP)
- 1963 Olds Starfire, what is it worth?
- '64 Olds LP Phonograph Record Album
- starfire gas ?
- 64 SF Conv't Cardboard Clips - Pictures?
- 61-62 olds f85 floor shifter
- Courtesy light
- HMM - Congrats to Wmachine / Kurt's '65 Jetstar I mention
- 62 olds idle stop solenoid tube and vac lines
- A few more questions for the detail-minded
- oil pan R&R in 74 Omega
- whitewall size
- 62 Starfire heat riser valve stuck
- bellhouse f85
- New to me Omega
- Jetstar I.......
- Some good updates and a couple questions for my 62 Starfire
- Cover for '63-'64 SF convert's
- Any trick to changing a fuel pump in a 394?
- 74 Omega carpet question
- 1950 oldsmobile delivery panel truck
- 1978 Olds Omega - Project Car
- 66 starfire body mounts
- 74 Omega parts/trim
- rear qaurter window
- A few general 62 Starfire questions and updates.
- 64 SF Conv't Trunk Pic?
- what trans to use?
- 62 Starfire Speedo Problem
- 62 Starfire Rear Main Seal
- 1975 Omega value
- Stalling
- Can anyone with a 62 Starfire provide me with some good pictures/info?
- 61 Dynamic shift linkage setup??
- 63 F85 made the news
- 63 Starfire Progress
- My new 62 Starfire has some minor issues
- 84 Firenza GT Hatchback
- Frame woes.....
- My 62 Starfire is here!!
