Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
bellhouse f85
Old Oct 16, 2011 | 09:51 PM
4x4jimbo's Avatar
bellhouse f85
i have a 61 f85 .it has a 215. i want to install a muncie m22 4 sp . what bellhouseings can i use i cant find one for a 215 anywere?
Old Oct 17, 2011 | 06:46 AM
The 215 uses a unique bellhousing bolt pattern, so only the 215 bellhousing works. The Rover bellhousings bolt to the block but won't accept the four speed. Fortunately, D&D Fabrications sells new repro bellhousings for the 215.
Old Nov 19, 2011 | 12:47 PM
4x4jimbo's Avatar
the t5 seems more realistic. any specific years i should look for ?
Old Nov 19, 2011 | 05:04 PM
Rickman48's Avatar
Good idea - M-22 would be way overkill!
Probably worth $16-1800 used.
Old Nov 19, 2011 | 11:59 PM
4x4jimbo's Avatar
yes but wouldnt it be great haha!. any suggestions on a rear end ... im going for a 3.73 gm as long as i can find one for coil springs.
p.s any certain year t5 i should look for . i obv dont want electric that run on comp parts so i take it 86 and under??
Old Nov 21, 2011 | 07:37 AM
I would suggest that you do a web search on the T5. Be sure you verify the tag number of the trans. There are a lot of variations out there, so be sure you know what trans you are getting. The 4 and 6 cylinder T5s have a VERY low first gear; with even 3.36 rears it's only good to the other side of the intersection. The late 1980s F-body T5s are world-class (thus stronger) and have a 2.95:1 first gear in the V8 versions. These bolt to the Muncie bellhousing pattern. Starting in about 1994, GM went to the Ford pattern T5 case, which requires an adapter that is sold by D&D.
mikkim129
Apr 27, 2016 03:49 PM
Shot Gun Rich
Apr 25, 2014 09:36 AM
BIGBAD455
Cars Wanted
Feb 1, 2010 07:17 PM
oldolds
Aug 23, 2007 06:33 PM
<c. larson>
Cars Wanted
Sep 23, 2006 05:57 PM
