Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
Convertible top question
Old Aug 26, 2015 | 05:29 PM
joemo's Avatar
Is there a way to raise and lower power convertible tops manually? The top on my 62 Cutlass seems to be getting weak and I would like to know if there is a relatively easy way to do it manually.
Old Aug 26, 2015 | 05:41 PM
Probably, but you would need to disconnect the lift cylinders from the top frame.
Old Aug 26, 2015 | 08:45 PM
On many models, the power top was an extra-cost option - it could also be had in a manual version.
In these cases, the manual version generally had a pair of springs where the cylinders were, to help at the hard point in the raising and lowering process. There may be an illustration of the arrangement in an Assembly or Parts manual.
Old Aug 27, 2015 | 08:27 AM
hookem horns's Avatar
Cylinders can be disconnected but it will be heavy when raising it. And try to flop back when lowering.
My driver's side cylinder is getting weak. Found I can reach back and give it a little help when first starting to raise it and it's OK after that. Borrowed time I know but other projects are higher on the priority list.
GoBigRed
Brakes/Hydraulic Systems
15
Oct 5, 2015 01:00 PM
ros6872
Oct 31, 2014 05:04 PM
cfair
Jun 30, 2012 10:07 AM
Bobac455
Aug 27, 2011 03:20 PM
Olds luvr
Dec 2, 2010 08:26 AM
