Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
63 Cutlass trans kickdown and other trim items
Old Oct 13, 2015 | 06:39 AM
gmiles's Avatar
I have an Edelbrock carb on my 63 Cutlass. I made a new throttle rod to work with the new carb and it has a tab for the kickdown lever to attach to. How do I set the kickdown with this carb? The factory manual is useless with the Edelbrock carb.
The kick down arm is spring loaded and wants to push forward. Is it as simple as adjusting it all the way forward then working backwards until I get the shift point I want?
Also, I need a few clips to hold the stainless trim on around the back quarter windows (2 dr post car) and some clips to hold the "oldsmobile" script on the trunk. I've checked all the obvious places (steel/rubber, etc) with no luck.
thnx
grady
Old Oct 13, 2015 | 10:06 AM
nonhog's Avatar
Registered car nut
Do you have a picture of the 1/4 clips? I can look.
Old Oct 13, 2015 | 11:35 AM
Start by reading this thread. In particular, scroll down to post #19 in that thread for photos of the linkage I made for the E-brock carb on my 62 F-85.
Be aware that the linkage is NOT a "kickdown", it is a throttle valve just like the one on the 200-4R and 700R4 transmissions. Adjustment has been purely by trial and error. I started with the rod adjusted short and incrementally adjusted it longer until the trans downshifted and upshifted acceptably. Mine probably isn't perfect, but it's close enough until I do the five speed swap.
Old Oct 13, 2015 | 01:17 PM
gmiles's Avatar
Here are pics of the clips. The bigger clips are used to hold the stainless trim on around the side windows. The smaller ones are used to hold the letters on the trunk.
And I'm reading the thread on the TV adjustment.
Old Oct 13, 2015 | 01:25 PM
gmiles's Avatar
And a few newer pics of the car.
Old Oct 14, 2015 | 02:08 PM
nonhog's Avatar
Registered car nut
Dang it! Forgot last night. Tonight!
Old Oct 14, 2015 | 02:12 PM
nonhog's Avatar
Registered car nut
Car looks nice!
Old Oct 14, 2015 | 08:45 PM
nonhog's Avatar
Registered car nut
have a few of those clips still attached to trim. I'll send them to you.
with trim for back up. no charge
PM me an address, may still have it but just to be sure.
Old Oct 23, 2015 | 09:44 AM
gmiles's Avatar
Got the trim parts yesterday. Thanks again. That's twice you've saved the car for me.
grady
Old Oct 23, 2015 | 10:07 AM
nonhog's Avatar
Registered car nut
grady
Glad to help!, look around and see if there is anything else you might need/want an extra of.
Really don't have much left but I'll be tossing most of what is left as I desire a cleaner shop than what I currently have. LOL
Old Dec 20, 2015 | 03:00 PM
Hetman's Avatar
Nice Cutlass!
I also have a 63 Cutlass (triple-black) and I am very unsatisfied with the way the transmission shifts, and I've been told it's "normal". Well, it makes the car completely unsatisfying to drive and I too wish to install a 5-speed manual transmission as Joe Padavano alludes to. Speaking of which, Joe, I'd love to hear anything about your plans for that swap! Thanks.
HWYSTR455
Jul 20, 2015 09:41 AM
88hurstolds
Jun 24, 2015 09:15 AM
rocketman77
Aug 3, 2013 05:44 PM
leadfoot067
Jan 6, 2011 04:55 AM
boehm
Sep 26, 2009 09:54 AM
