Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
1962 cutlass f85
Old Mar 28, 2016 | 10:15 AM
2093138A's Avatar
1962 cutlass f85
Does anyone know how to change the ignition key without having such a hard time? Bought ignition and all other lock cylinders and was wondering what's the way to do it since I'm sure some of y'all have done it
Old Apr 9, 2016 | 07:24 PM
jetfire88's Avatar
It can be done with the switch in the dash.
Insert key and turn to the left.
Push a paper clip into the hole on the face of the cylinder.
Turn the cylinder as far left as it will go and pull towards you.
Reverse to install new one.
If you don't have the original key, you can go to a locksmith and they should have master keys to allow you to get the old cylinder out.
Good luck.
Jim
Old Apr 9, 2016 | 09:04 PM
2093138A's Avatar
Thank you for replying to
my post was hoping someone would help, should any locksmith have it? Still haven't got to it due to me buying a house so I have went forward but I think I'm going to try to install it and see if my car even cranks haven't even tried to start this baby
Old Apr 11, 2016 | 01:19 AM
jetfire88's Avatar
Any locksmith should have a master set, but the odds are better if you look for someone who has been in business for a while.
The car looks pretty solid and a good one to start with.
Old Apr 11, 2016 | 06:13 PM
jetfire88's Avatar
I just verified my instructions against my car and I simplified them too much.
You have to remove the small chrome escutcheon from the center of the bezel in order to see the release hole. There are specific tools to do that, but you can use anything that will span two of the holes (large washer, extra-wide screwdriver, paint scraper, coin, etc.). You can even use a small screwdriver and hammer and tap it around anti-clockwise. It usually isn't very tight.
I have attached 2 pix that show a switch with and without the ring. The ring is what holds the switch to the dash.
After you remove the ring, you can easily remove the switch from the back and take it to the locksmith to swap the cylinder.
Installation is the reverse.
Good luck.
Jim
6inarow
Aug 27, 2019 11:22 AM
tailfins
Mar 14, 2012 09:55 AM
1k442
Aug 24, 2011 07:07 AM
trademen
Nov 28, 2010 01:01 PM
1k442
Mar 3, 2010 08:03 AM
