Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
'62 Cutlass Fuel tank sending unit
Old Jul 4, 2017 | 02:18 PM
Torqueline's Avatar
Hello
I am not having any luck finding a new tank sending unit for the car.
Is there an after-market part out there that works in the '62 Cutlass?
it looks like a 63-64 Buick Riv unit might work.. Anybody have any info on it?
Old Jul 5, 2017 | 06:24 AM
Originally Posted by Torqueline
Hello
No one sells new ones. I've seen NOS originals on ebay - you just need to keep looking. There are vendors who can rebuild your original also.
Are you sure the sender is bad? I was convinced mine was bad until I pulled the gauge pod and cleaned the contacts in the connector. Suddenly, everything in the dash worked, including the fuel gauge.
Old Jul 5, 2017 | 07:37 AM
Torqueline's Avatar
With the ohms check, mine is flakey.. I am going to install EFI on the car and need a 3/8" vs the 5/16" suction tube.. So I, was hoping I could find another and mod it OR find one the will work that already has the 3/8 and return line
Thanks for the info
Old Oct 9, 2017 | 09:58 PM
Torqueline's Avatar
turns out they do make an aftermarket sending unit reproduction unit..
If anybody is interested.. here is the link... http://www.classiccarautoparts.com/g...ng_units2.html
Old Oct 10, 2017 | 04:12 AM
Nice find, though apparently they only sell the single line version and not the two line version for cars with fuel return.
Old Oct 10, 2017 | 06:28 AM
Torqueline's Avatar
My tank actually has a return line in the top of the tank.. I did not know there was another version with the return in the sending unit
Old Oct 10, 2017 | 07:37 AM
jensenracing77's Avatar
Are you sure the other line in the tank is not a vent? The Jetfire had two lines and I believe any Cutlass with A/C had it.
Old Oct 10, 2017 | 08:43 AM
My 62 wagon with the 185 HP Cutlass motor (and without A/C) also has a return line on the sender.
Old Oct 10, 2017 | 09:20 AM
Off topic but do you happen to have the little T fitting that screws into the Fuel pump for the fuel dome? I need one of these and cannot find anyone with an extra. This was only found on the two line system and the dome was to help aid in a continued forward motion of the fuel. I am missing the T fitting for our automatic Jetfire.
Old Oct 10, 2017 | 09:28 AM
Let me see if the Jetfire parts car still has that part on it. I'll have to get back to you.
Old Oct 10, 2017 | 12:01 PM
Torqueline's Avatar
Yes, I have the return line as noted inthe service manual on the top of the tank with a factory inlet fitting..
I have a vent line right up near the gas cap..
At least that is how I understand it..
Is this incorrect
dallasite21
Oct 1, 2021 05:21 PM
pfergy600
Oct 4, 2014 05:29 PM
1carsick
Oct 17, 2012 09:10 AM
1k442
Nov 9, 2010 08:31 AM
