Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
62 starfire exhuast manifolds
Old Apr 9, 2022 | 05:15 PM
toms1966rgtop's Avatar
Son and I working on my late dads starfire. So far 5hrs and 3 broken bolts but they are off!
Old Apr 10, 2022 | 08:39 AM
Charlie Jones's Avatar
Phantom Phixer
Now all you need to do is pull the heads off, to get a decent shot at drilling those broken bolts out.
BTW that is either a '63 or 64 engine judging by the aluminum front timing gear cover.
Old Apr 10, 2022 | 02:23 PM
That would be something, never was told a engine was swapped out.
Old Apr 16, 2022 | 01:39 PM
Manifolds done, welded nuts to the studs and heated with map gas !
Old Apr 16, 2022 | 02:56 PM
rocketraider's Avatar
Oldsdruid
I never had that good of luck fooling with exhaust bolts.
The basic 394 engine is the same 61-64. To make sure you still have a Starfire engine see if the engine number has the S suffix. It should be stamped above center exhaust port on the left head. Course a 4-barrel SkyRocket from a Super 88 or Ninety Eight still packs a 330-horse wallop.
FTolliver
Jun 7, 2021 07:36 PM
Oldpac62
Mar 1, 2020 04:31 PM
jensenracing77
Jun 30, 2016 06:12 PM
carmfromchicago
Nov 17, 2006 07:13 PM
