Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
65 starfire wheel question
Old Nov 9, 2017 | 04:50 AM
justintiime's Avatar
mmmm, starfires
I'm looking to replace the 15" torq thrust wheels on my 65 with some 18" torq thrust M wheels.
Does anyone know the bolt pattern and back space I need to run?
I've used online calculators and even trusted some vendors with other cars I've worked on, and even their reliability is at about 50% so I'm hoping for some real world answers
Old Nov 9, 2017 | 10:16 PM
Bolt pattern is 5 x 5".
OFFSET (not backspace) should be close to zero. Backspace depends on rim width. Offset is independent of rim width. Depending on the wheels you pick, you may not be able to find zero offset. My 67 D88 has TTO wheels. 15x7 fronts with -.25" offset on the front and 15x8.5 rears with -1" offset. These are not made in zero offset.
Old Nov 11, 2017 | 11:39 AM
mmmm, starfires
ok, thank you. that's a good start
1962oldsguy
May 19, 2019 08:08 PM
Kyle's 77 Cutlass
Jan 1, 2014 09:06 AM
Oldssupreme
Feb 3, 2013 06:26 AM
Oldssupreme
Feb 3, 2013 06:24 AM
ss427
Jan 13, 2008 08:57 AM
