BT-33-2 Measurements?
I've always been curious about whether or not the throttle valve adjustment is correct on my 1963 F-85, and as I understand it, the original BT-33-2 gauge for checking the adjustment is difficult to find. I know that there are a few folks who reproduce this tool, but I think if I knew the dimensions between the holes and the stud on the tool, I could at least see if my adjustment is close or not. The transmission seems to shift as it should, but then again it can be hard to tell with the Roto5 since it's not like most other automatics.
So, does anyone have an original BT-33-2 gauge who would be willing to carefully measure the distance between the stud and each of the two holes?
jensenracing77
Sep 28, 2022 08:01 PM
