Looking for temp gauge sender.
Old Mar 29, 2019 | 03:26 AM
JoeyOldsmobile's Avatar
Hello,
I own a '47 olds coupe and was lucky enough to find an original gauge set including the temp gauge.
Right now my car is fitted with a 350 chevy engine (yes a rocket will come later) and a mechanical water temp gauge.
I would like to connect the original one but to do that I need to find a electronic sender that I can connect to the gauge and into the block.
Anybody an idea of what resistance I should work with or does any sender work.
I guess this also works with connecting the + to one side and the other side to the sensor and it meassures the resistance no?
All advice is welcome.
Thank you
Joey
Old Nov 15, 2019 | 02:14 PM
Hey you all. I still have this problem that I cannot find a sender to work.
I have ordered a aftermarket sender with 50k resistance cold and 7k at 180 degrees but the needle doesn;t move.
If I connect the + of the gauge with the - it shoots to overheat straight away so I know the gauge works.
I also connected a 100k potentiometer and it did move the meter but it didn;t liked the current that much and smoked away
Any info that can be usefull is helpfull.
As stated above my 47 olds has a chevy 350 in it now. (yes it will get a olds block later on)
Old May 15, 2021 | 08:23 AM
Still nobody who knows the resistance?
If anybody with a 46-48 olds with original engine could measure the resistance of there temp sender that would be the solution for me.
thanks
Joey
Old May 15, 2021 | 09:35 AM
Thirdcoast's Avatar
You might try this company;
https://www.lectriclimited.com
I have found several hard to find parts and info..
Thirdcoast
Old May 16, 2021 | 10:17 AM
maineolds's Avatar
Bump in the hopes you get the info you need. Sorry I don’t have your year so I can’t measure.
Old May 16, 2021 | 10:49 AM
66SportCoupe's Avatar
Original temp sensor for 1947 Olds will be a TS-11 replacement. Is the car 12v or 6v?
WTony
Jul 11, 2013 02:40 PM
spate51
Apr 20, 2013 02:45 PM
spate51
Nov 21, 2012 10:45 AM
Emreozd
Feb 19, 2012 06:27 AM
PGH Cutlass
Oct 31, 2011 12:59 PM
