Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
Fixes for seal on heater valve
Old Jul 31, 2018 | 10:03 AM
Torqueline's Avatar
1962 Cutlass
The heater valve on the firewall... The plunger rod passes thru a rubber seal when moved..
Well... that rubber seal, after 56 years is, apparently, a bit dry.... so I have some weeping of coolant when the engine is running...
Question is: Is this repairable? I can not see how to get it removed and replaced.
Can you find a suitable replacement valve?
Part number for an original, in case I can find one that is still pliable?
Suggestions for a fix?
Old Jul 31, 2018 | 12:20 PM
What vehicle are you working on?
Old Aug 1, 2018 | 07:38 AM
Tedd Thompson's Avatar
X2 and a picture also please. Do you have water / coolant on the floor?.... Tedd
Old Aug 1, 2018 | 08:19 PM
I am not aware of a DIY way to fix this. You can either have yours rebuilt or buy an N.O.S. valve. Neither of those options is inexpensive. I took the third way - I just adapted an aftermarket cable-operated valve from NAPA and bypassed the original one. No, it won't have the capillary tube, but I don't really drive mine much in the winter anyway.
Old Aug 16, 2018 | 07:45 PM
Torqueline's Avatar
I actually found a new one and replaced the valve.. I also found a guy that rebuilds them as well.. So there are options
Rustbucket2
Jun 11, 2018 04:33 PM
louie
Feb 21, 2018 08:53 AM
Eightbanger
Apr 15, 2016 09:24 AM
Tedd Thompson
Mar 20, 2014 08:41 PM
ctrain22
Aug 30, 2009 06:19 AM
