Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
Oldsmobile F85 with rochester 2GC carb
Old Dec 7, 2021 | 01:03 PM
willycrack's Avatar
What size is the inlet thread on my rochester 2GC carburetor. I purchased a new old stock carb and it doesn't have an inlet fitting. Thanks
Old Dec 7, 2021 | 02:02 PM
If the carburetor has no inlet threads, I believe the correct size is 7/8-20 male (Thread length: .525") 5/8-18 female w/ inverted flare - same for both the 2G & 2GC (7/8" diameter inlet with 3/8" steel fuel line). You'll need to validate this, but I'm rather confident regarding the sizing at least up until 1972. I've read there was a change in sizing from 1973 forward, but I don't know.
Here is a self-tapping fuel inlet fitting: https://quadrajetparts.com/self-tapp...ing-p-130.html
More inlet sizes. Some you can go oversize or downsize based upon configuration parameters. Note some have extra length if required: https://quadrajetparts.com/inlet-fittings-c-72_87.html
Old Dec 7, 2021 | 02:13 PM
willycrack's Avatar
my carb is a small bore 2GC that came on an F85 215. the threads are either a 1/8" npt or 3/8"-24 just not sure which one
Old Dec 7, 2021 | 02:46 PM
willycrack's Avatar
The carb came off of a 61-63 F85 with the 215 engine
Old Dec 8, 2021 | 05:47 AM
The threads are NOT NPT. They are straight threads. The seal is the inverted flare.
Old Dec 8, 2021 | 06:17 AM
willycrack's Avatar
Thanks for that info. I didn't want to screw in the wrong thing and mess up the threads.
Drbigblock
Jun 25, 2016 07:16 PM
My62F85
Apr 21, 2015 11:49 AM
roberer
May 9, 2014 08:27 PM
John1963
Jul 20, 2012 02:29 PM
4x4jimbo
May 11, 2012 10:03 PM
