View Full Version : Chassis/Body/Frame
Pages :
6]
- Battery tray permantly bolted on
- New vinyl top done!
- Suicide doors
- Rear window leaking?
- fuel tank 49
- 1977 cutlass brougham
- control arm bushings 1963 olds
- 1964 jetstar 1
- 1968 442 lower front deflector?
- Bumper bracket bolts
- TOWING HITCH FOR 71 Cutlass Supreme
- rocker panel molding question
- Removing Body Questions?
- front shocks
- Bent trunk hinge..
- Correct brake line tube clips for '72 Cutlass Supreme
- Upper Control Arm Bushings
- will steering box from 85 cutlass wrok on 85 delta 88?
- Lady’s rear enhancements…
- Regaining camber on my 64 F85
- 66 cutlass frame
- 65 f-85 vent window latch
- Stabilizer Linkage (Help)
- Upper ball joint installation
- torque specs
- Compatible hoods for 69 Cutlass
- reinforcing Bracket?
- Can't get any grease through a fitting.
- Need help with king pin replacement
- 1964 Jetstar center link - sources??
- Difference between Reproduction and Original Bumpers
- frame damage
- Front coil springs with A/C
- Door hinge restoration
- Larger wheel studs?
- Stock Front Sway Bar on '72 Cutlass Supreme
- 1972 vista cruiser
- Problems w/ 66 Centerlinks?
- 65 F85 frame question
- Finding a place to store car for resto
- is this normal???
- Unknown hose coming thru firewall
- Fan shroud
- 72 cutlass a-arm question
- 71 Cutlass Frame Diagram
- 1972 Cutlass Length and Width?
- Lifting Body from Chassis
- Post car doors 64-65
- need help for rust on rear frame rail
- 71 Shock Fitmit
- How to get my frame off the body?
- Painting my Frame?
- Tried some POR-15
- How to ID saginaw or Thompson steering linkage on a 65 88
- little help on support bolts
- Front lower control arm bushings
- Front spring rate
- PST Tie Rod Assembly Question (68 Vista)
- Lower control arms
- POR-15 Experiences.
- 72 cutlass frame
- January Muscle Car Review
- Do i have the right bumper on my Cutlass -71?
- axle and rear upper control arm bushings
- Help me narrow down my suspension/steering problem.
- Frame interchange - 1978 & 1986
- 1964 Super 88 Lower Front Control Arms
- 64/65 CUTLASS FRAME INTERCHANGE
- Should I be worried?
- rad support question
- '65 Cutlass Help with frame off resto
- A-body upper ball joint question
- Vista Cruiser Lower Ball Joint
- automatic column shift conversion to floor console
- Core Support Question
- Visor for 53 Olds Super 88 4 dr. Sedan
- upper control arm bushings Help
- rear control arm bushing
- Changing Motor Mounts
- Battery Tray
- A-ARM SWAP?
- Centre Link / Drag Link... help!
- window fuzzys
- torque specs for a-body rear control arms
- whats the difference?
- New gas tank
- Code A/B mystery
- What color for underhood parts on 72 Cutlass?
- repairing metal on glass window
- Repro / N.O.S. Body Mounts
- Upper Control Arms: O.E.M. Source?
- Frame Off
- Ball joint rivets instead of bolts?
- What rear sway bar is this??
- SSIII wheel refinishing!
- Shock install??
- '61 98 fuel line routing?
- 67 del mont88
- 65' rag joint question
- Frame swap
- Off-the-shelf rear coil springs
- Steering column adjustment?
- Floor patching,,,first time,,,,what do u think
- Brake drum / sway bar / wheel colors - 72 A body
- Center cap refinishing?
- Custom cruiser wheels?
- Will '76 Cutlas Disc Brakes Interchange With Earlier Years?
- Why does autozone not list front spings
- my first rust repair not to bad
- Floorpans
- Shock Mounts?
- mirrors
- 1965 Cutlass rocker panel
- Correct Coil Spring Compressor for 67?
- Frame question Olds Delta 88
- 67 delmont 88 parts
- 67 Cutlass Upper Control Arms - Interchange?
- 1971 grilles
- Help needed for engine and transmission mounts.
- aftermarket outer wheel housing
- rear tires ... 69 442
- rear springs/tire clearance 1969 442
- body mount holes
- Lower wishbone bushings Delta 88
- rust around body mount holes
- HELP! Gas pedal removal
- replacing front coil springs 67 -any tips?
- convertible frame replacement
- Steering Shaft Installation Help
- Frame Straightening
- gas tanks problem
- wheelsize for 1966 442
- HELP 64 Starfire front A arm bushings
- 69 Cutlass S with a lean
- How do i.....
- Ride Height 72 Convertible
- 70 vs 71/72 Radiator Core Support
- Leaf spring separators
- change coil springs on engine swap?
- Question on Prep for Applying a Sticker?
- need a rad support bushing kit - 66/67 A body
- 1970 cowl tag help needed
- coil springs part #
- Anyone had floor pans redone?
- door lock assembly repairs any experience?
- '66 hood options
- Structural/frame,body integrity
- A-arm bolt breaks, front wheel falls off...
- Is this the right style of muffler/exhaust hanger?
- tow hitch for a 64 starfire?
- 69 Conv Rear 1/4 Window Guide Roller Installation?
- Lock and Tumblers 1972
- package tray braces
- Control Arm Brackets
- New here! dropped spindles to a 98 -65
- Frame interchange
- Mystery Bracket
- 71 cutlass help
- convertible frame off rotesserie help??
- rear suspension
- Hood latch color?
- Rims for the 80s cutlass.
- NOS part # 4229957-what car is this for??
- 1968 Cutlass front drum hub
- 1964 dynamic 88 and starfire frame swap?
- anybody have picture of windshield channel repair panel?
- side vinyl wood
- A-Body 442 fender braces
- rust issues
- wheel color
- OAI hood, possible price?
- windshield reveal moulding
- 1/4 panel extension part # 4229957
- 72 Convertible rear suspension
- Dulled paint on my car
- Good tires???
- Original left front fender
- Mini Tub 72 Cutlass 2dr Ht
- Window Fuzzies
- I need to strip the paint off my fiberglass hood
- What is the maximum back spacing on a Cutlass Cruiser?
- replacing quarter panels help
- 1964 Starfire 2 dr coupe frame question
- 1968 Cutlass Post coupe to sport coupe coversion
- Aluminum accessory refinishing
- Fan shroud mounting brackets....
- New Quarter Panel and Trunk Replaced
- Drivers side side view mirror
- Ground straps
- 72 cutlass convertible 455 barn find
- Headlight Bezel, '87 Cutlass Cruiser RH
- front fenders
- Trim and moulding stud repair
- 1967 Cutlass Restoration
- No cookie cutter rod here...need help
- 70 442 paint question
- Rechrome or replace bumpers
- new guy signing up
- Fixing Rust at Rear Window
- steering issues
- Chrome trim removal
- Part ?? 56 Olds
- Custom Cruiser A-Arm bushing specs
- '66 F-85 & '74 442
- Major rust repair needed
- Suspension
- Hood interchange 71 vented and 72 unvented
- Trim and lettering removal
- rust issues
- 65 Delta 88 Steering
- Help Please
- dash rusted--advice?
- Sport Mirrors
- Back end saggin
- What wheel size to use?
- 442 & Cutlass ride height
- NEED LEFT FRONT FENDER 66 DELTA 88
- some 1 hit my cutlass..
- Bottom Radiator Bracket??
- '66 and '67 442 Hoods
- Can anybody help me open my hood(50 88) ?
- 65 f-85 442
- '57 trim for gas door?
- Assembly manual
- Cutlass Fender Patch question
- Anyone used the repro bumpers? 71-72 cutout
- bushing kits for 1962 ninety eight?
- Lower Steering Shaft Bearing
- 67 Olds rear window clips
- 66 Vista trim and body ?
- Bad springs from national distributor
- 78 cutlass replacement body panels
- swirl marks/abrasive scratches
- 1977 olds cutlass
- Chrome spraypaint?
- CUTLASS BODY TRIM
- dayton wire wheels
- 1951 rocket 88
- aftermarket body parts for 83 delta 88
- 1964-65 Cutlass Frames
- 1966 Cutlass Supreme rear bumper needed
- 1962 olds starfire right side mirror
- Door Hinge Repair
- 1966 body color code HH
- Stone guard needed
- frame dimensions / wheelbase for a 1933 Olds?
