Upper ball joint installation
Old Apr 12, 2010 | 01:44 PM
defiant1's Avatar
I went to install new upper ball joints in the 70 Cutlass S. The original ones were riveted in, so I took the rivets out and removed the ball joints.
I went to assemble the new ball joints ( rubber boot, boot retainer) and place inside the hole in the control arm (from the top down) but the boot retainer would not fit. Its diameter is too big. So I took the off the boot retainer and placed the ball joint in the hole and installed the retainer from the bottom side.
Question is: Is this correct or do I have the wrong ball joints?
I want to install everything so I can drive car one of these days, but this issue is holding me up....
Old Apr 12, 2010 | 02:02 PM
bccan's Avatar
You ended up assembling it correctly. Boot & retainer go over the stud, below the control arm.
Old Apr 12, 2010 | 03:02 PM
defiant1's Avatar
Thank you sir. Now I can get to gettin'
Old Apr 13, 2010 | 09:05 AM
RAMBOW's Avatar
Ben
Sorry i didn't get back to you sooner- I wanted to look at my extra set of original arms before i answered.
The other gentleman is right on... the tin plate & rubber go on from teh bottom.
Old Apr 13, 2010 | 09:32 AM
defiant1's Avatar
No problem. I figured I'd ask someone who was basically at the same point in dis-assembly/assembly.
arcee1951
Mar 15, 2014 11:03 AM
brown7373
Mar 12, 2014 06:28 PM
shovel55
Mar 3, 2013 12:57 AM
Ranzan
Sep 7, 2010 09:17 PM
f85mark
Nov 30, 2009 12:13 PM
