replacing front coil springs 67 -any tips?
Old Jun 11, 2009 | 12:29 PM
Flye's Avatar
Got new set of coil springs from Fusick. Going to try to get front back to more stock looking height (and so I can get pan under oil drain).
I've replaced front coils on other models including A body GM.
Anything I need to know on these to look out for?
Any angle better than another to try to get them out?
Thanks,
D
Old Jun 11, 2009 | 12:53 PM
Danny Wiseley's Avatar
Pretty much the same as the A-body, except you have to be careful and not destroy the speedo cable and housing that goes in the left spindle.
DW
Old Jun 11, 2009 | 12:58 PM
Be careful and make sure they are seated correctly.
Old Jun 11, 2009 | 07:46 PM
DW
Pretty sure Dan's talking about his 67 Cutlass. The front wheel speedo cable is only on the full size cars - not an issue here.
Old Jun 11, 2009 | 07:52 PM
Wow, I would have sworn the subject line said 67 Delta! Guess I'm seeing things. . . Sorry for the misinformation.
DW
Old Jun 12, 2009 | 05:46 AM
Be careful when compressing the springs. The right way to do it is to rent a spring compressor from your local auto parts store. If you use a floor jack under the lower control arm to compress the spring be extra careful. If one of those springs pops loose when it is compressed it could send you to the emergency room or the morgue. Good luck.
Old Jun 12, 2009 | 05:56 AM
Don't even think about using a floor jack. I you need a spring compressor, I'll rent you one for the price of postage.
Old Jun 12, 2009 | 05:57 AM
Good man Jamesbo. I just mentioned it because I know it is the "Redneck" way of doing it.
Old Jun 12, 2009 | 06:09 AM
DAN76's Avatar
Englishman
Live and learn!
I didn't jack the car up high enough when i removed mine. The lower arm sprung down like donkey kick and ended up with a nice hole in the floor from the recoil
I fortunately survived!
Old Jun 12, 2009 | 01:21 PM
67 Cutlass's Avatar
Originally Posted by DAN76
Live and learn!
X2!!!!
Rent a spring compressor for a few bucks! It isn't worth your own safety or anybody elses safety
I think Autozone gives you back the money when you rent a tool from them and return it.
Think about the rental as a cheap insurance policy. NOBODY gets hurt!
bumblebee72
Jul 28, 2015 12:33 PM
Kid Thunder
Suspension & Handling
May 11, 2015 10:46 PM
JamesRustle
Jun 20, 2013 09:59 AM
Winger67
Jun 19, 2013 06:55 PM
mcutlass1969
Aug 6, 2006 03:47 AM
