Cutlass Fender Patch question
Can someone tell me if the patch panels from a 1971 Chevelle will fit a 1972 Cutlass?
This is the lower rear part of the front fender.
I found a good deal on a pair for a Chevelle, but I want to make sure they are useable before I buy them.
Thanks for your help.
Might be able to modify and trim one to make it work but depending on how bad yours is I would just cut out what you need and make a new patch with 20ga sheet metal.
The fender profile is different. They won't work, which makes them a not so good deal.
