Off-the-shelf rear coil springs
Old Aug 7, 2009 | 10:48 AM
Lady72nRob71's Avatar
Okay, it's spring time!
I am interested in getting some off-the-shelf rear springs for my 72 Cutlass to replace the old originals.
I am upgrading to the stock firm-ride setup.
The current Gabrielle Hijacker shocks will be replace with Bilsteins.
The boxed control arms and sway bar will be added.
Ride height needs to remain at factory specs.
I have heard some positive comments on Moog.
I noticed many here use the Moog CC501 coils, which are variable rate.
The alternate is the Moog 5413 heavy duty constant rate.
--If any of you used these, please comment on them!
Is variable rate a good advantage? Is the HD ones too firm?
I notice Rockauto also has AC Delco springs also. I am assuming these are newly made, but are they really built to the same specs as the originals?
Heavy duty constant rate is part # 45H2013
They are a bit costly, also.
--Anyone used them??
I am aware of Fusick's custom made springs, but not sure if i want to shell out the high price when Moogs might work well also.
Richard, are you using Eibachs on the rear??
Old Aug 7, 2009 | 11:45 AM
Nilsson's Avatar
I have the Moog HD on the rear purchased from Rock. Stock ride height and not to firm.
Old Aug 7, 2009 | 11:52 AM
You might also look at Kanter. They probably have springs for your car. Moog is a top quality manufacturer. As I recall, I used Moog ball joints on my 1964 98 many years ago.
tommyd
Mar 23, 2015 01:01 AM
stlbluesbrother
Paint
Sep 6, 2011 10:34 AM
aristellier
Dec 9, 2009 09:36 AM
bigwillystyle
Dec 5, 2009 02:03 PM
