1968 Cutlass front drum hub
Old Jan 29, 2009 | 07:35 PM
CQGlenn's Avatar
I have a 68 cutlass convertible with front drum brakes. I spun a race in the front hub and im looking for a replacement. If anyone knows where I can get a new or used one please let me know.
Thanks,
Glenn
Old Jan 29, 2009 | 07:44 PM
rocketraider's Avatar
Oldsdruid
Sounds like a good opportunity to upgrade to disc brakes. Any 68-72 drum brake A-body car can donate the hub, so you're not totally limited to 1968 Oldsmobile.
Old Jan 30, 2009 | 05:52 AM
Oldsguy's Avatar
Past Administrator
And I just want to say welcome to our site. Good luck with your repairs.
Old Jan 30, 2009 | 01:59 PM
rocwal's Avatar
Smile 68 cutlass front drum
Hi. welcome ,this is a great site for anyone with an Odsmobile . post your location and mabey someone in that area can direct you towards parts,or have some.
rocwal
Dan B
Old Jan 30, 2009 | 02:46 PM
It's even better than that. Any 64-72 A-body (Cutlass, Skylark, Chevelle, LeMans), any 67-69 F-body (Camaro/Firebird), or any 68-74 X-body (Nova, Omega, Ventura, Apollo) with drum brakes have spindles that interchange. Also, since the steering arms bolt on, the spindles are the same on RH and LH. Most people throw these away when they upgrade to disk brakes (though you CAN convert the drum brake spindles to accept disk brakes with very minor machining).
Old Feb 2, 2009 | 12:05 AM
Yellowstatue's Avatar
Talking Drum hub
I would go to your local auto parts place and see what they have....I go to Car Quest...bearings and races fit a lot of different things over a lot of years ...I got a u-joint for my '53 Oliver off the shelf at Car Quest a couple years ago...and brake shoes and wheel cylinders for my '57 last year '07
Old Feb 2, 2009 | 06:11 AM
I was too hasty in responding to the original guestion. The title said "hub" and I read "spindle". Sorry for the confusion. Having said that, the hub should be common to any of the cars I noted above with drum brakes. The 64-68 Jetstar 88 also used the same hubs.
sweet56olds
Jul 11, 2015 08:40 AM
604Cutlass
May 21, 2015 01:40 PM
yeahbuddy
Feb 5, 2014 11:44 AM
wesste
Wheels and Tires
Jul 22, 2013 07:10 AM
wesste
Jul 7, 2013 04:32 AM
