Problems w/ 66 Centerlinks?
Old Mar 11, 2010 | 08:52 PM
RAMBOW's Avatar
Ben
I've read some stuff in the past of problems when doing front end rebuilds and trying to replace the centerlinks... specifically 1966...
What is the main issue- the studs from the centerlink won't fit the pitman arm/idler arm, or the holes for the inner tie rods are the wrong diameter?
I'm just trying to figure out the issue before i order the last few peices.
I've already got the PST basic front end kit, and plan to buy the centerlink, idler & inner tie rods soon before i start the project.
I was looking at my car and at my neighbors 66 chevelle, and his centerlink is considerably bigger than the one on my car- concerned me that mine has the 1965 smaller one and i may have issues ordering "1966" parts...
help would be appreciated!
Thanks-
Ben
Old Mar 11, 2010 | 08:55 PM
gearheads78's Avatar
car guy
You just have to have it all match. the idler, pitman and drag link. There is a small one and a large one. I found out the hard way. None of it will work with each other if not matched.
Old Mar 11, 2010 | 09:01 PM
RAMBOW's Avatar
Ben
thats what i'm afraid of... So i'm guessing mine is the smaller one- So i would need to get the idler & centerlink for the 1965 small option?
Are the inner tie rods specific to that centerlink or no?
Old Mar 11, 2010 | 10:07 PM
RAMBOW's Avatar
Ben
So i went out the garage and crawled under my car and my neighbors 66 chevelle again...
Measured my centerlink vs his- mine is 13/16s and his is 7/8s.
In all the parts catalogs- 66-67 is listed at the same PN- and there is no size listed. 64-65 they list two size options on is 13/16 and one is 7/8.
Does this mean i should order the 1965 idler arm & centerlink?
Richard do you know what size you wound up with on your car?
Curious.. my car was build 3rd week of Feb 1966... What month was your car built?
Old Mar 11, 2010 | 10:40 PM
RAMBOW's Avatar
Ben
OK- i know i'm retarded replyoing to my own thread... but another question/thought.
Are the power steering pitman arms on the cutlass the same as the chevelle? Maybe i should just buy a new "CORRECT" 66/67 pitman arm, then i can get the beefier "CORRECT" 66/67 centerlink & idler arm.
Is there a benifit in running the bigger unit?
Old Mar 12, 2010 | 10:21 AM
Run to Rund's Avatar
Kanter has both sizes. Your car should be 7/8"; a few 66 models still had 13/16--I had an early 1966 Fremont built 6 cyl that was 13/16.
Old Mar 12, 2010 | 10:43 AM
wmachine's Avatar
Trying to remember member
Hey, go with who gives you the best answers.........:
If it is like the difference between the Saginaw and TRW components, I believe the pitman arm and everything "out" from there are different.
I think this is a case of "bigger is better", and I'd get it converted.
Old Mar 12, 2010 | 10:53 AM
car guy
Mine had the 13/16 and I got the 7/8 when I ordered. Months later after everything was painted and detailed I started assembeling the chassis and nothing would fit each other Ended up upgrading to the larger stuff and used the 7/8 one.
Old Mar 12, 2010 | 02:05 PM
RAMBOW's Avatar
Ben
Gonna see if i can find a local used 66/67 pitman arm for a good price- if not, i'll just get the replacement 13/16ths centerlink- I'd prefer to upgrade, but its been ok on there for 44 years, i'm sure a new one will be just fine too...
chasman414
Jun 25, 2020 07:05 AM
jrbarrie83
Jul 9, 2006 09:26 AM
jf857
Apr 28, 2006 07:24 AM
bmbraun
Feb 25, 2005 12:17 PM
<lunatic>
Jan 6, 2005 07:21 PM
