Frame interchange
Old Feb 25, 2009 | 11:01 AM
madmax's Avatar
Frame interchange
I currently own a 67 442. Several months ago a friend gave me a 67 Cutlass supreme 4 door. I have completly dismantled the car. I plan to restore the 442 in the future. Meanwhile I am considering restoring the frame and suspension from the 4 door so that I can do the body and drop it right on. From what I have found the frames are the same for two door and four doors. Can anyone confirm this?
Old Feb 25, 2009 | 12:46 PM
Run to Rund's Avatar
Yes. however, there were two suppliers, A.O. Smith and Pontiac. If the bottom front of the crossmember under the oil pan looks like a top and bottom half welded together, both stamped to give the tongue that is under the center link, it is Smith. The Pontiac had a welded on piece in the front. The Pontiac frame won't have the two positions for the rear upper control arm through bolts like the Smith. note 67 is not the same frame as 66--for 67 they went to rear coil springs with pigtails on both ends; 66 had full diameter tangential ends at the top of the rear coils.
Old Feb 26, 2009 | 06:43 PM
madmax's Avatar
Thank you. I was starting to get concerned that I wouldn't be able to use it and it would be just taking up space.
Old Feb 26, 2009 | 06:59 PM
64Rocket's Avatar
You should check and make sure of the wheel base. I think the 4 dr has a different wheel base than the 2 dr.
Gene
Old Feb 26, 2009 | 07:09 PM
mugzilla's Avatar
is Fast Enough ...
I used to like using boxed frames off convertibles. Lotsa luck finding one at pic a part now ...
Old Feb 26, 2009 | 07:31 PM
Gene
The 1964-67 cars used the same 115" wheelbase for 2 drs, 4 drs, and flattop wagons (Vistas were 120"). The 1968-72 cars used different wheelbases for 2 drs (112"), 4 drs/flattops (116"), and Vistas (121").
Old Mar 1, 2009 | 09:53 AM
madmax's Avatar
Thanks to everyone for their replies. I had a chance to check today and it is a smith. So it looks good. But I must say the idea of the boxed frame is tempting. And considering my brothers 66 lemans convertable is sitting in one of my garage bays. I wonder if he would miss a frame?
Old Mar 1, 2009 | 05:51 PM
mugzilla's Avatar
is Fast Enough ...
Old Jun 28, 2009 | 09:01 PM
oldstrio's Avatar
64,65 frames are not the same as 66,67 frames the front frame hornes for the core support are different
Old Jun 29, 2009 | 07:06 AM
66400's Avatar
66 Lemans frame will not work for a 67 442. Oldsmobile radiator support requires wider spacing between frame horns.
Henry
taa442
May 31, 2012 04:59 AM
RobbieQ
Oct 9, 2011 07:42 AM
Lady72nRob71
Dec 19, 2009 02:11 PM
442scotty
Dec 4, 2009 08:38 AM
bpeesy
Aug 20, 2009 01:47 PM
