Centre Link / Drag Link... help!
Old Oct 1, 2009 | 12:10 PM
scubastever's Avatar
this is not my car lol
hi again, hope you're doing well...
i'm just wondering if anyone has had any luck sourcing a Centre Link (some call it a Drag link) for a 66/67 Cutlass?
i have a Moog Part number ds-749, but it only covers 68+ model years..
from what my research tells me, Moog, Spicer & Metal tech make one- but i cant seem to track down the part numbers for a 66/67 Cutlass, no AC, 330ci engine
HELP!!
(pssst...Joe!)
Old Oct 1, 2009 | 12:23 PM
Have you looked at RockAuto? They might carry this part. If not, I'm not sure where you could get it since it is a non-wear item.
Old Oct 1, 2009 | 01:11 PM
svnt442's Avatar
Rock Auto doesn't list one.
Old Oct 1, 2009 | 01:29 PM
gearheads78's Avatar
car guy
To add to the problem you need to measure the size of the bar. I think one is 13/16 and one is 7/8. Your 67 may not have the same issue but my 66 did. The stud size to the pitman arm is different. I found out the hard way and ended up having to replace my pitman arm to get it to work. I looked all over but I think I got mine off EBAY from this guy.
http://cgi.ebay.com/ebaymotors/Cente...Q5fAccessories
Old Oct 2, 2009 | 09:00 AM
thanks! and actuaslly since my car is technically a 66 i will probably run into the same problem you did..
i have a MOOG DS749 on order and will pick it up this weekend. ill measure my bar tonight so i can be sure to get the correct size.
oh, and anyone telling you this is a non wear item is incorrect.
there are pivots at either end of the bar that (even when fully greased up) can exhibit play due to wear.
Old Oct 2, 2009 | 10:02 AM
Nilsson's Avatar
you are correct on the link being a wear item but the pitman arm is a non wear item.
Old Oct 5, 2009 | 06:05 AM
Wink
FYI...updates..
the stock centre link is a 13/16" thickness. the DS749 MOOG part is thicker, so i didnt buy it.
ill be instead buying the idler/pitman/centrelink off ebay that richard suggests
onwards & upwards~!
Old Oct 5, 2009 | 09:20 AM
Run to Rund's Avatar
1965 "should" be 13/16" and 66-7 "should" be 7/8". you can get both at www.kanter.com
Old Oct 5, 2009 | 12:50 PM
well, it seems the bar length overall is same, so the only benefit to going upsized to 7/8" is a heavier mass, and a stiffer link between the tie rods. seeing as i'm going the larger wheel / tire route; i think upsizing to the 7/8" link with the idler & pitman is a wise choice..
this guys sellin them as a package deal..!
http://cgi.ebay.com/ebaymotors/ws/eB...tab%3DWatching
Old Oct 5, 2009 | 01:13 PM
Cut-67's Avatar
I ordered one earlier this this year I can't remember right off the bat from who and I am at work right now but I will let you know from where when I get home later tonight or tomorrow evening. I believe it cost me around $60.00.
Old Oct 5, 2009 | 01:32 PM
Cut-67's Avatar
The Parts Place
217 Paul St ·
Elburn, Illinois 60119
(630) 365-1800
Price 89.00 I paid 101.00 with shipping
Old Oct 6, 2009 | 09:28 AM
DRAG LINK 64 65 66 67 BUICK SKYLARK CENTER LINK DS-740
Please wait
Image not available
Item condition:New
Sold For:US $79.53
BILL DEMMER
34
Jun 8, 2021 11:45 PM
RandyS
Nov 30, 2019 02:46 AM
cfhcar
Mar 4, 2016 02:29 PM
hmartin
Ninety-Eight
Mar 4, 2014 11:23 AM
shovel55
Jul 7, 2012 04:20 PM
