my first rust repair not to bad
Old Jul 17, 2009 | 09:47 AM
1973olds98's Avatar
The rear window sill was brittle and I had no problem taking it out...I actually had to cut the lip off and replace it with metal...It took me about 8 times before i got the factory form back...I actually used naval jelly to dissolve as much rust as i good which actually did a good job..I thin grinded the helll out of it...I then used eastwood rust convertor and coated everything and made sure it was smooth, now I am just waiting for a new vinly top...Pretty good for my first repair job take alook at the pic...There was still some fuzzies left from the old top but that will be covered up by the new top...Right under the glass the paint is wrinkled a bit,,This is part of the rubber seal i painted to blend it in..After the new top is on its goin look like nice...The car is dusty so there is some dust in the pic that just needs a good washin..It was leaking water so bad it start to rust all up under the roof of the trunk....I took a bead blaster and removed everything i seen...The grinded it more,,,Coated all the metal with eastwood rust converter and then sealed it..Came out real nice...check pics
Old Jul 17, 2009 | 09:59 AM
Good job!
Old Jul 17, 2009 | 10:03 AM
1973olds98's Avatar
The trunk needs one more coat of sealer,,but it looks pretty good.. The middle pic is the way it looked . I tokk about 25 pics of the window when it was out and the vinly top ripped back..My son happend to erase them before i uploaded the pics..
Old Jul 17, 2009 | 10:09 AM
Nilsson's Avatar
What exactly did you use in the trunk and what method of application did you use, it looks really nice.
Old Jul 17, 2009 | 10:13 AM
1973olds98's Avatar
here is some more,,Once again all rust removed with a cheap bead blaster the grinded some more,,rustconvertor applied then sealed with a truck bed coating..It needs another coat I ran out of coating..
Old Jul 17, 2009 | 10:19 AM
1973olds98's Avatar
Well first I sanded all of the rust on the floor...Mostly all of it came up...Then I used naval jelly to disolve as much more as i could...Naval Jelly is awesome when it comes to disolving rust...It pretty much left me with a good clean floor...I then cleaned it with a degreaser...And then coated in with eastwoods rust convertor ( 2 coats) And then rolled a rust-oleum truck bed spray on the entire surface of all the metal in the trunk. It came out pretty good..I just need to buy some more coating and give it one more coat..I missed a few spots to i seen when i took pics
Old Jul 17, 2009 | 10:26 AM
Oldsguy's Avatar
Past Administrator
Good work. Is that a TV antenna on the trunk lid?
Old Jul 17, 2009 | 10:48 AM
1973olds98's Avatar
It sure is and thanks
Old Jul 17, 2009 | 11:23 AM
1973olds98's Avatar
here is a pic of the tv antenna
i think i need a signal convertor now,,,lol
Old Aug 11, 2009 | 08:00 PM
marzgtp1's Avatar
Olds-Can
great job on that rust
I was thinking of do it myself also now I will just jump on it.
Old Aug 12, 2009 | 07:01 AM
1973olds98's Avatar
i took my car to about 4 bodyshops and they all said 1500-2000,,,,,I was like wtf,,So I went and bought a case of beer and started the project myself,,,,i took my little mig welder and some sheet metal and grinder,,,,I pulled the window because the bead seal needed replaced anyway and i didnt want to hit the window with my grinder,,,I cut the weak rusted metal out..The bad parts were right under the corner window on both sides,,,I then took my 7 inch and 4 inch grinder and went to town grinding the surface rust from the remaining metal,,,,,I then let naval jelly soak in the metal and dissolve any more rust,,This stuff work realy good...I repeated that step several times using alot of the jelly....I grinded it some more...Forming the lip to look like factory is where it got hard...But it wasnt bad...I then coated it down with eastwoods rustconverter....And then coated it with por-15,,,,,Then painted it......I had about 20 hours of labor in it and only about 100.00 in supplies,,that damn rust convertor and por-15 is alot of $$$$$$$$$,,,,It should last longer then me here on earth....I also drilled 3 small holes in the channel and some small drain hose to drain off any water that comes into the channel instead of it just sitting there which is what caused the problem in the first place,,,,,good luck and let me know if you need some help..
Old Aug 12, 2009 | 08:50 AM
Joeypete's Avatar
Speaking of rust...anyone have a good recommendation for getting rust off of chrome bumpers? My Toro has some light rust on it...well the bumper part anyhow...I know in the past I bought some product that removed it. Can't remember what it was called though.
Old Aug 12, 2009 | 02:25 PM
1973olds98's Avatar
turtle wax chrome polish and rust remover works good if it isnt real bad,,,,Change polishing cloth frequent or u will scratch the heck out of the bumper...If the rust is pitted end there is nothing u can do...
Old Aug 12, 2009 | 04:37 PM
Joeypete's Avatar
Thank you for the suggestion. I used some polish on it, but I don't think it had rust remover in it. The rust isn't horrible but I know there are pin holes on parts of it...so I'll try to get it as best as I can.
Old Aug 12, 2009 | 08:11 PM
1973olds98's Avatar
I bought it at autozone but my bumper is gone,,I am buying one off another member here that has good chrome
Old Aug 31, 2009 | 01:58 PM
marzgtp1's Avatar
Olds-Can
I have afew holes on my floor pans and was wondering what ga to on the floor 16ga or14ga 12ga?
Thanks,
Old Aug 31, 2009 | 05:18 PM
1973olds98's Avatar
i used 12 guage,,It will thicker then the stock,,It felt like it anyway,,Worked real nice..
Old Aug 31, 2009 | 06:14 PM
marzgtp1's Avatar
Olds-Can
Good, my buddy just brought me a 4'x4' sheet from his job
odddoylerules
Apr 21, 2014 07:54 AM
airmale
Nov 13, 2013 11:15 AM
easytobedead
Paint
Apr 10, 2009 06:16 PM
lshlsh2
Body work
Mar 4, 2009 03:27 PM
