- Oil pressure hose broken
- mysterious misfire
- Bucket seat rail spacing
- 55 Olds 2 door holiday
- With or WO A.I.R. or AIR
- cowl tag decipher 66 442 or not
- Looking to buy a one peice rear main seal for 371 engine
- Gas smell from 66 442
- What does the "W" reference?
- Freon question
- 1995 oldsmobile delta 88
- 4 speed console
- 55 Olds 88 2Dr Hdtop
- Need guidance
- V8 Intake Manifold Lift Bracket Washers
- Head numbers and difference
- Torque Readings vs. Bolt Head Size
- Charcoal Canister
- '72 Cutlass Supreme R-134a
- How do you install Edge Guards on a 72 Cutlass supreme?
- How do you remove the 442 numerals on the trunk?
- Frustrated
- Replacement for factory AC and Heater 69 442 conv.
- VIN numbers
- data sheet for ´67 98 convertible
- Fuel injection swaps
- Air Cleaner Housing Side by Side Comparison
- 1970 w-31
- Help with car history!
- Engine babbiting for OLD olds
- t56 behind an olds how to
- Production Numbers
- wild about cars
- 67 442
- Gm part number for 1971 w 27 10 bolt axle cover
- OAI air filter element cross reference chart
- top won't line up
- Lighten a 425 crank
- The water decoke trick.
- 1955 324 specs:
- 72 Cutlass S cowl tag decoding help
- What is it?
- 59 Power Steering Pump
- Engine date code lead time to Trim plate date
- 1972 Oldsmobile Cutlass info.
- Build sheet on the gas tank
- 58 olds a/c fan motor
- water pump
- wiper motor numbers
- ID cam
- Here are the dimensions of those Power Steering Pump Spacers
- door latch problem
- 66 442 radiator
- Wiring diagram
- Uploading pictures
- Gauge Repair
- '73 Delta questions
- Tcs or tvs
- 57 fuel pump
- Fuel Line Fire Risk
- paint chart fo 68 cutlass
- service manuals
- New to Olds Motors...need advice
- 215 valve covers
- speedo cluster order
- 1970 Radiator Codes and Appilcations
- Reproduction Turn Signal Lever 1970 A body
- Windshield Washer Pump - Reporduction Woes
- engine paint color
- 1972 Cutlass Holiday Coupe
- Engine ID help
- convertible Roof-Rail Seal adjustments 69 442
- high beam low beam
- A/C switch-relay question-68 442
- Oil Pressure problems 63, 215
- '68 Fuel Pumps / Carb Line
- Specifications 1959 Ninety Eight
- 350 intake gasket
- Collum tilt to Floor tilt
- NOS or not?????
- Need to find the EFE valve on 83 3.8 A code
- 3800 Belt Slipping off Pulleys
- 1971 Cutlass hidden serial number
- Decoding numbers on 350
- Brake Booster Rebuilds
- Air conditioning
- Help w#6 heads
- 55 s88 kingpin change
- #5 heads in 68
- Need a brake genious
- Sand blasting aluminium
- 70 manual trans floor hump
- 4 Speed hump
- 1987 442 Need Vacuum Routing Help!
- Stubborn seal
- 4 speed console adapter
- Paint code for a 66 cutlass...
- Trim Code 980-R
- Site Logging me out
- 66 Olds 98 Power top
- Whats the trim-TR977 and the date-12A for this 72?
- 64 F-85 steering wheel
- 8-Track Removal
- So school me on fuel pumps...
- body mounts...
- fuel gage off
- TVS in A vs B/C body cars 1970
- A/c recirc. Air door diagraphm - 66 442
- 1955 Olds 4BBL Oil Bath Air Cleaner
- Edelbrock 1411
- Fluid recommendations?
- 66 toro headlight cannisters
- Correct Lower Rd Hose 1970 Cutlass
- Engine Option for 1970 442
- Correct Pulleys for Y72 Option
- L69 venturi size?
- Fan Clutch Applications 1970
- 71 fuel sending unit
- Fuel Gauge
- Halo vinyl top
- Stabil - for the winter---
- 62 Olds Starfire windshield removal
- Addinga remote mirror to a non remote mirror car
- Quadrajet 7042250 2981 NC ?
- olds transmission
- how rare is my '66 98 two door??
- Earlier Olds crankshaft pulley
- Part numbers
- intake manifold ID
- Fender skirt fit
- 76 Seat Belts cross reference
- neding help finding out what manuel transmission options came in my 1964 f-85 cutlass
- '72 442 voltage regulator location
- Valve Covers
- Inconsistency In Tech Info.
- Octane ratings
- Need rubber firewall insulation retainers for 67 442
- 67 Buick Reviera steering column into a 68 Olds 98?
- Motor mount application list
- 1961 Olds 98 Holiday 394
- Leaded/Unleaded gas history and engine info
- Electric choke wiring
- 425
- Are Chvy And Olds Starter Drives Same?
- 71-72 vacuum diagrams
- Decoding Help on a 1964 442
- 55 olds
- 70 Cutlass convert 4 speed production #s
- Where is the Engine ID number on SBO?
- 1955 Olds Fuel Bowl Filter
- Water Pump Lengths
- 1966 Cutlass Frame Specs Needed
- Links for replacement parts.
- Overheating Problem 70 Cutlass
- BBO Con Rods Material?
- vaccum advance on hei not connected
- HEI distributor help required
- starfire engine
- High oil pressure,oil leak
- Edelbrock heads 455
- 57 Ninety Eight stalls in hot weather
- oil pump installation
- What is it ?
- trunk paint
- Vacuum Modulator
- 68 F85 options, Factory order info
- '55 Custom Headers in FL
- 69 Clutch safety switch wiring
- detonation - solution
- cowl tag help
- 62 Olds Starfire
- 70 hei conversion, use what plugs?
- option codes
- Where to get 68 h/o dual gate sales supplement
- Need Help Decoding Firewall Tag
- 1957 Olds J-2 Specs
- 72 Olds 350 Supreme Engine ID
- rocker to valve spring clearance
- Headers and Supremes
- All American car brochures and advertisements
- 455 motor
- Dedicated to Classic Oldsmobile
- Conversion to HEI
- 425 Manifolds
- 1957 olds- fan shroud only on air condition cars?
- Clasic Car CARFAX report
- Restoration research Icon
- Correct Color
- 72 Old Cutluss ~ Problem
- 56 olds 88 vacuum diagram
- Q-Jet ID
- 1970 Cutlass body Tags
- Painted numbers on frame...
- Paint Code Question
- '77 Cutlass question?
- 67 Cutlass Referance photos
- 67 Cutlass trunk stickers and firewall markings
- flywheel part number
- Variable Vane Torque Converter
- Wire Wheel Solutions for Mid 60's Olds (semi-long)
- Help from someone with lots of manuals
- breaking in a rebuilt 350
- Power steering pump spacer/with AC
- W-36 watch
- power 101... or engine rebuild 101?!?
- pics
- Qjet floats
- Differential
- '71 Fisher body manual
- GM VIN Decoder 1972-2009
- Canadian Engine in a Lansing Olds
- 72 455
- 65 Starfire gallery pics
- 350 Olds in a Firebird
- Camshaft basics
- Cam terminology
- My improvement for edelbrok hop stoppers
- Coolant leak & radiator questions
- 40 Olds engine
- Junk yard finds
- joe padavano
- th400 problem
- Horn button removal
- Using quotes
- front end alignment
- Need help with a W31 ID
- 62 olds dynamic 88-4dr. sedan-canadian
- Oil
- Check the obvious first
- Repro Tripower Intakes
- Exhaust donuts
- Vacuum Modulator
- Low cost A-body disk brakes
- Did you miss me?
- No, I haven't forgotten you all
- Technical Topics
