Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
door latch problem
Old Apr 22, 2013 | 12:25 AM
455 Olds 442's Avatar
door latch problem
Hi, 1972 442 drivers door issue. In this vid, have you experienced this problem before? The drivers door external button can stick in. Light pressure down on the handle can release it. Is this an old mechanism or because the door needs realigning?
thanks
Richard
Old Apr 22, 2013 | 02:04 AM
lemoldsnut's Avatar
have you tried a little lube?
Old Apr 22, 2013 | 08:26 PM
Thanks but
Thanks but I haven't got the car yet. IN transport across Australia as we speak. I have never had to realign a door before, is it easy to lift the door a bit? The trunk lid is a bit out of kilter as well. Is this relatively easy to fix up? As for the button sticking in I wonder if the mechanism is faulty/old and it is going too far in.
Old Apr 23, 2013 | 10:05 PM
Hoffman2099's Avatar
If the door is sagging, I believe that means the door hinges need to be rebuilt. And maybe a new door striker if it's worn out.
Old Apr 24, 2013 | 05:56 AM
lemoldsnut's Avatar
I think from what has been said your best advise is to find a good body shop that can do a set of hinge pins and bushings and maybe a door stricker. Then align the doors. A good amount of lube on the latch.
The stripes might not line up after that is done. Would have been best done prior to painting the car.
Old Apr 25, 2013 | 09:47 AM
ls98's Avatar
Are the hinge pins worn?you can check this by lifting on the rear of the door,if it moves up and down then the pins may be worn,should be able to see the movement at the hinges,if the pins are tight then you need to adjust the door and the striker.
Old May 6, 2013 | 06:42 AM
Lifting on the rear of the door doesn't move the hinges at all they are quite tight. I am going to try loosening the top and bottom hinge at the door side and then lifting it a cm or so. It only needs 2 or 3 mm movement at the top of the hinge end of the door. Fingers crossed.
Old May 8, 2013 | 05:33 AM
I am thinking about putting a thick washer in behind the bolts at the bottom of the door. Do you think that will work? The striker looks fine though it has moved a couple of mm.
Old May 20, 2013 | 05:39 AM
Problem nearly solved
Thanks to all. I have managed to loosen the hinge bolts against the door post and lifted it the distance I needed. Then the striker had to go up a bit. The latch is still dicky so I have ordered a new one from Fusick.
Thanks guys,
Richard
Chesrown 67 OAI
Feb 18, 2011 05:52 AM
Danielle's 71
Sep 21, 2009 04:06 PM
squirtacious
Aug 27, 2009 12:29 PM
a64olz
May 4, 2009 07:26 PM
pippy
Nov 7, 2007 07:00 AM
