Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
72 Olds 350 Supreme Engine ID
Old Jan 2, 2010 | 08:11 PM
johnspd22's Avatar
Having a problem in selecting an Engine ID sticker (on oil filler tube). I have a '72 Supreme w/ a 350 and automatic. Engine originally was a 2 barrel, but I have upgraded to a 4 barrel with all factory parts. What engine ID would this engine have from the factory (I am trying to match factory markings with this option upgrade)?
From the chassis manual, it appears that the Code QD would be applicable, except this option combo only appears to have come with a manual transmission.
In addition, two 2 barrel codes are listed with the Supreme, QB and QC. Does anyone know the difference?
Thank you in advance for your assistance.
Old Jan 2, 2010 | 09:08 PM
johnspd22's Avatar
Please excuse misfiled post. I meant to post in the General section.
Sorry for the confusion. Thank you.
Old Jan 3, 2010 | 08:25 AM
Lady72nRob71's Avatar
John, here is the complete list from the assembly manual. Most likely you would use the QK code.
The supreme in 72 came standard with the 4bbl, but the first buyer got a $40 credit to downgrade to a 2bbl.
BTW, did you change the throttle cable? Do you know what the difference is between the 2bbl and 4bbl cables? Reason i ask is I am thinking mine is from a 2bbl.
Perhaps a supermod can move this thread to the general section...
Old Jan 3, 2010 | 05:29 PM
johnspd22's Avatar
Cool. Thanks for the info.
When I did the swap, I changed the whole setup including throttle cable and throttle cable bracket at carb.
Amazing, anyone would think of a downgrade to a 2 barrel for a $40 savings. My car also has the optional bench seat. This was also an option, I believe, off the standard console/buckets etc. I would have preferred he left that box unchecked. Lol!
Old Jan 3, 2010 | 05:45 PM
You wouldn't happen to have noticed any differences with the two throttle cables and brackets? I am curious...
Lots of people downgraded carbs in hopes to save gas. However, if they would have just kept their foot out of it, there would be no difference and the power on demand would have been nice to have.
Yep, the bench seat with armrest was an option for the supreme. Seems a bit backwards to me; I would have preferred the buckets. However, many people liked benches back then, esp if they had big families. These intermediate size cars seat 6! How many new regular "big" cars can do that???
Old Jan 3, 2010 | 05:53 PM
johnspd22's Avatar
I still have all my 2 barrel parts. I will check and let you know if there is a difference.
Old Jan 4, 2010 | 04:24 AM
johnspd22's Avatar
Brackets are pretty different. My 2 barrel was just a small angle bracket with attachment for throttle cable. 4 barrel bracket, mounts to back 2 bolts of carb. Depending on mounting holes locations on 2 barrel manifold (don't have it to compare - I got rid of it), geometry does not appear to be that different.
I have my old throttle cable in another bin that wasn't handy last night. I will try to dig out, but I do remember the length being different between the two. It wasn't radical, but there was a difference.
Do you need a 4 barrel cable/bracket? I am going to talk to someone about some parts later today.
Old Jan 4, 2010 | 05:13 AM
A picture of the 2bbl bracket would be helpful, but I ~think~ I have the right bracket as it bolts on as you describe...
I might need it... My cable seems to be .5 to .75" too long. It will not pull open the carb's secondaries. Pedal goes to the floor instead. I have plans to crimp on another stop on the cable at the pedal to see how that works.
I am thinking my cable might have been replaced when the carb was replaced with a service carb and the wrong cable was used. The car did originally come with a 4bbl. The service carb has the same looking linkage, too.
Old Jan 5, 2010 | 04:20 PM
johnspd22's Avatar
Check Inline tube (www.inlinetube.com, 800.385.9452). They have repro 4 barrel throttle cables for $39. Bracket is also ther for $22 if you need it. Bracket picture matches mine exactly.
I checked with a parts guy I use, and he does not have an original.
Murco
Feb 25, 2015 03:12 PM
1973Omegaman
Nov 7, 2014 07:28 AM
undercar1
Aug 23, 2014 02:43 PM
805cut
May 3, 2012 08:11 PM
dharlett
Sep 23, 2009 03:30 PM
