Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
#5 heads in 68
Old Jun 18, 2012 | 05:17 AM
72 Supreme's Avatar
#5 heads in 68
Are these the correct heads for my 68 350, what are the valve sizes and compression ratio for the stock engine?
Thanks,
Doug
Old Jun 18, 2012 | 07:22 AM
Thanks,
Doug
#5 heads were factory installed on ALL 1968-69 350s, including W-31s. All had the same 64-ish cc chambers (actual chamber volume varies with manufacturing tolerances). CR was changed with piston dish size - large dish pistons provided 9:1 CR, small dish 10.25:1, flattops (on W-31s only) were 10.5:1. Valves were 1.875/1.562 on all except W-31s, which got 2.000/1.625 valves.
Old Jun 19, 2012 | 07:35 AM
72 Supreme's Avatar
# 5 Heads
Joe,
Thanks for the info!
Doug
64 CUTLASS KEN
Dec 7, 2020 06:43 AM
olds4life
Dec 25, 2012 12:56 AM
Oldsmaniac
Nov 1, 2010 06:37 PM
gearheads78
Nov 10, 2009 09:31 PM
DarkStar
Oct 21, 2009 07:35 AM
