Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
oil pump installation
Old Jul 9, 2010 | 01:51 AM
jet tech's Avatar
Smile oil pump installation
I'm ready to install my oil pump on rebuilt engine. I've heard I need to weld the pick up tube in place after setting to the right hieght. I've also heard these welds can crack, letting the pick up fall away from the pump, What do you recomend?
Old Jul 12, 2010 | 09:22 PM
goatwgn's Avatar
Its a little bit of work, but drilling a small hole in the body of the pump, then tapping it and installing a small set screw is a positive way to retain the pickup.
Old Jul 13, 2010 | 06:36 PM
jet tech's Avatar
Thanks for the info, that would work great too. I had thought about using aircraft ss safety wire to wire the tube in place. In the end I just used my wire welder and this was after talking to a number of people. If it doesn't work ya'll will read about it here.
Redog
Oct 20, 2015 03:29 PM
Al Sanchez
Sep 6, 2013 03:30 PM
86pontiac
Feb 17, 2010 11:24 AM
scott_442
Feb 14, 2009 09:37 AM
