Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
'72 Cutlass Supreme R-134a
Old May 19th, 2014, 03:01 PM
RickH's Avatar
I bought a restored ,72 Cutlass Supreme which has the A/C changed to R-134a. I've had it about three years and the A/C needs a shot of R-134a.
On the sticker that is on the evaporator, it says that it has been changed to R-134a, but then it has 8.5 lbs. listed as well.
Does anyone know if that the correct spec as it seems low to me. If it's incorrect, how many pounds should I bring it up to for a refill?
RickH is offline
Old June 7th, 2014, 07:22 PM
You need to use gauges to measure the pressure on the high and low sides. The weight of refrigerant matters only when charging a completely empty system as there is no way to determine how much is still in a charged system, but the high and low side pressures can show when the proper amount of refrigerant is reached.
By the way, that 8.5 pounds sounds very odd. Most systems use around 3 pounds.
Fun71 is offline
Old June 10th, 2014, 06:20 PM
Majored in rear tire demo
2Olds4U's Avatar
There are a couple of rules of thumb when changing to R134A.
One is that you will only use about 75% of the charge capacity that R12 required. Just look up the R12 specs and do the math.
The second is that you are not supposed to top off 134A, but I do it all the time in .2 lb increments. Your car should have a sight glass. Just top up until the bubbles disappear.
Using a set of gauges will help tremendously. The high side should be approximately 2.5 times ambient temperature. The low side someplace in the 30-35 range.
HTH
2Olds4U is offline
Old June 10th, 2014, 07:23 PM
1970-W30's Avatar
Vintage Air say's ignore the sight glass when charging their 134a systems, go by the temp/pressure only. Temp/pressure charts are easy to find on Google.....
1970-W30 is offline
Olds Dad
August 21st, 2014 12:59 AM
m455sx
July 31st, 2012 03:52 PM
olds70supreme
August 1st, 2011 05:22 PM
Oldsmaniac
June 4th, 2011 05:20 AM
joades
March 11th, 2009 10:51 AM
Quick Reply: '72 Cutlass Supreme R-134a
