Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
Engine ID help
Old Oct 9, 2012 | 08:10 PM
1932j2's Avatar
Question Engine ID help
Hello all. c
Can anybody help me with proper ID on this? Olds engine, block casting on bellhousing is No.561747, Intake casting No. 57145. Stamped on deck of block between No.5 and 7 cyl. is R239123. It is complete with carbeurators. It has a muncy m 20 four speed connected to it. This is in a 1932 Ford (sorry) roadster i just bought. any help is greatly appreciated. thanks, Jim
Old Oct 9, 2012 | 09:15 PM
59-59-59's Avatar
No need to repost the same exact question twice but here it goes. 571145 is a '57-'58 J-2 triple carb intake. If you have #16 cylinder heads, it's telling me you have '57 or '58 heads. Check the bell housing area for a number. If it is something like XXXXXX-4 it is telling me you have a 4 inch bore which equals a 371.
Old Oct 9, 2012 | 10:32 PM
1932j2's Avatar
Exclamation engine ID
The moderator stated the newby forum is not for this purpose so i put it in the tech area. It is for introducing ones self. Just following what I thought was proper protocal. The bellhousing casting number is plainly stated in the previous question. Thanks, Jim
Old Jan 11, 2015 | 04:46 PM
The Eye's Avatar
Ok, so I have checked in several places I still no answer ......
Oldsmobile rocket 88 engine casting number .... 561747
The question was asked in 2005 by a guy from the netherlands ... H.A.M.B
In 2008 a guy from oregen, posted he had one, but no info ... H.A.M.B
In 2009 a guy from san diego posted he had two, but no info ... H.A.M.B
In 2011 a guy from RI posted he had one, but no info ... Hotrodders.com
The question was asked here in 2012 .... Still no answer
Oldsmolie block casting number 1949-1965 .... Doesn't have it listed
Muscle car club, oldsmobile casting 1949-1979 ... Doesn't have it listed
442.com, casting list ... Doesn't have it lsted
...... So does anyone know the casting year for the oldsmobile block with a casting number of 561747
My new rust bucket have one in it and
It is a 1949 Oldsmobile 88 with a display hood
Just trying figure out this cars history
Old Jan 11, 2015 | 05:51 PM
Octania's Avatar
It is quite common to misread casting numbers.
nothing "similar" at
http://musclecarclub.com/members/cas...smobile1.shtml
which appears otherwise pretty comprehensive.
here is a block casting # pic
http://speednik.com/files/2013/09/chevyasylum-com.jpg
maybe your 561747 is not the BLOCK casting ID.
Or maybe you have a hella rare casting.
if we go by the concept that they made up casting / part numbers more or less sequentially, then it dates as about a 1956 block.
Old Jan 12, 2015 | 04:42 AM
The Eye's Avatar
Your right, misreading a rust bucket is easy to... But pictures are cool
Old Jan 12, 2015 | 04:48 AM
The Eye's Avatar
This motor is in a 1949 olds 88
1949-1964 ... Casting number is on bell housing , right side and is 6 numbers
Old Jan 12, 2015 | 05:12 AM
okie88's Avatar
561747 is the casting number for a 303.
Old Jan 12, 2015 | 05:15 AM
The Eye's Avatar
Hey thanks, any idea on the year
And again thanks
Old Jan 12, 2015 | 05:25 AM
okie88's Avatar
There is a series of letters and numbers between the 1st and 2nd exhaust ports on the drivers side of the block, below the head (visible with the head on). They should start with a B. If you give me that series I can tell you what year it is.
Old Jan 12, 2015 | 09:33 AM
Octania's Avatar
Please cite the source of this information so that we can all find it from now on. I would like to add this # to my PN database.
Kind of funny that the internet has NO mention of this casting number at all. You would think somebody somewhere would add that to a published list.
As for the picture, it sure looks like 561747 to me, but it's so close that there is no telling what part it is on, or where at on that part.
Back to "hella rare casting"
Does not mean valuable necessarily, might be the first year of 303, and few left and fewer folks that care to build or maintain the smallest of the small.
Get okie88 the factory application stamp and watch the info flow
Old Jan 12, 2015 | 07:12 PM
The Eye's Avatar
The picture is of the casting number, which is located on the bellhousing, passenger side... 3/4" tall
Old Jan 12, 2015 | 07:18 PM
The Eye's Avatar
And I'm guessing that it has a story behind it .... It sits under this hood
nolabigdawg
Nov 16, 2014 06:45 PM
805cut
May 3, 2012 08:11 PM
MJAKS462
Apr 15, 2010 02:34 PM
Olds luvr
Mar 17, 2010 06:57 PM
pinky
Oct 1, 2007 11:24 AM
