67 442
67 442
Could use some help with casting numbers to verify a 1967 442 engine. What should the numbers be? Car was built first week of January. Thanks in advance for any help. Is there a casting date for the heads? If so where are they located?
E block
C heads
E intake manifold. 2027xxx carb, I forget, '156 or similar.
X LH exhaust manifold
W RH ""
OG auto trans, WOG ?? for W30 ?
One of the heads (front of the passenger side head or rear of the driver's side head if they were swapped during a valve jobe) will have an engine unit number that begins with the letter "V":
Of course, that just proves that one head is from a 442. The C heads were used on all 1967-69 BBOs (except W-30s and most H/Os), and the 400 block was used in the Turnpike Cruiser and VC.
Casting date codes should typically be within 30 days before the build date of the car; there have been some instances of casting dates up to 90 days before, but that's less likely. Obviously no casting dates can be AFTER the build date of the car.
I seem to remember something about casting numbers on the engine being Julian dates. Can someone explain the Julian date? Where can I find the casting date of the block, intake manifold, exhaust manifolds, etc?
Julian date, numbers 1-365 or 366 for leap years. Example Feb 2 = 33 or Aug 6 = 218 or Dec 31 = 365.
Block casting date located at back of block by distributor, will be a number between 1 and 365.
Intake forward of carb, exhaust manifolds on the side.
Henry
